- Thank you received: 2
stock settings for vm24 fuel screws
- blink543
Adam james
- KZB2 650
- Thank you received: 265
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- blink543
KZB2 650 wrote: Stock setting is 1 and 1/4 turns out from "lightly" seated....... mine are about dead even with the surface when adjusted to that...... I have mine out 1 and 3/4 now with the mods and improved but keep yours around 1 and 1/4......will adjust mine closer with the new carb tune this summer.
you are talking about the fuel screws right?
Adam james
- KZB2 650
1978 KZ650 b-2
- blink543
KZB2 650 wrote: The brass air screws that at the outside rear of the carbs.
no I'm talking about the screws under my bowls that control the fuel. not the fuel bowl plugs. my carbs have a girl screw under each bowl. it's a sharp brass needle
Adam james
- blink543
Adam james
- blink543
Adam james
- KZB2 650
Clymer says the same so yes 1 and 1/8th turn out.
1978 KZ650 b-2
- blink543
what's an air screw type? u only have one thing to adjust on yours?KZB2 650 wrote: Ok that's the pilot screw type carb and mine is the air screw type that doesn't have that on the bottom ...... my factory manual says 1 and 1/8th turn out from lightly seated for that...... so very close to the same.
Adam james
- KZB2 650
1978 KZ650 b-2
- blink543
KZB2 650 wrote: Yes..... here's one thing the Clymer doesn't show the difference as good as the factory manual ..... in it (Clymer) look under the break down and it will show the pilot screw assembly on the bottom you have for the "pilot screw type carb" and since mine is the air screw type shown in the break down it only has that and no pilot screw at the bottom.
yeah I noticed that too!
Adam james
- blink543
ok so 1 and 1/8 for the pilot screw on the bottom. factory setting. right?
Adam james
