Fuel level 4mm under gasket. That means...
- car5car
- Banned
08 Mar 2016 21:39
It is about 1/8". That means fuel will be over gasket, when bike is on side stand.
What can I use to cover bowl gasket with?
96 Yamaha Royal Star
82 Yamaha Virago 920
Re: Fuel level 4mm under gasket. That means...
09 Mar 2016 05:51 - 09 Mar 2016 05:51
The gaskets shouldn't need a sealant. If they are old & hard, replace them. If they're in decent shape, you can try soaking them in liquid wrench silicone spray lubricant, let them sit a while, then install. I was able to rejuvenate some old gaskets by soaking overnight --- they were basically the same paper gaskets as the 1000E.
Last edit: 09 Mar 2016 05:51 by martin_csr.
09 Mar 2016 06:54
I don't disturb old gaskets. Mine are 20 years old. I use a light coat of grease to help seal them. I did that once two years ago, no leaks. If they're damaged, replace them.
