1978 KZ650C Petcock Leak
- Flooredd
- 1978 KZ650C
08 Mar 2016 20:23 - 08 Mar 2016 20:29
I've run into a bit of a pickle. I've got a leak coming from the petcock. I pulled it apart and found the culprit. So I think, "I'll just get a rebuild kit and slap that thing together." I've searched far and wide and I cannot find the specific kit that will fit this petcock, which makes me think this is not an original petcock. Does anyone else have this same style of petcock with that diaphragm that has that pin hole? If I can't get a new one, is there anything that I can use to patch it with that the fuel won't just eat through? Are there any other petcocks that I can get that are a direct bolt on? Thanks in advance! Apparently my pictures are too big to attach but I'll link the pictures in dropbox.
www.dropbox.com/s/jdbrmxqb1ja2y0n/20160308_205002_HDR.jpg?dl=0
www.dropbox.com/s/uleatt9d354i9m2/20160308_205031.jpg?dl=0
www.dropbox.com/s/h5f6j0jskmy85z7/20160308_205059.jpg?dl=0
If it were wise, I wouldn't be doing it.
Last edit: 08 Mar 2016 20:29 by Flooredd.
Re: 1978 KZ650C Petcock Leak
09 Mar 2016 06:17 - 09 Mar 2016 06:27
Your bike has the so-called hat diaphragm. I'm not sure if there's anything available to replace it.
There's a pretty good topic about it over at the KZ650.Info site, but I couldn't find it.
The bolt-hole spacing of your stock petcock should be 44mm. Z1Enterprises.com may have an aftermarket Suzuki vacuum petcock that will fit. KZR search = Dr. Suzuki by gargantuchet (sp?). I think most of the pics are gone, though.
You could install a manual fuel valve. search eebbaayy for yamaha raptor fuel valve 44mm or something like that.
super cheap are available, but I would get the made in Japan Yamaha part. ~$30. they come in a couple of versions, depending upon the year range.
stuff to check on a replacement: bolt hole spacing. fuel port OD. main pickup tube length. extension below tank --- some are tucked up close to the tank, while others hang down some. and might contact the carb top. ??? or just go by the bolt spacing & don't worry about that other stuff.
Last edit: 09 Mar 2016 06:27 by martin_csr.
The following user(s) said Thank You: Flooredd
- Flooredd
- 1978 KZ650C
09 Mar 2016 17:48
Well that's not the news I wanted to hear! So the best route is to toss this one and buy new? I guess I'll bite the bullet and do that. Maybe it's an unpopular opinion but I actually really like vacuum petcocks. I'll search around for one and let you know what I find. Thanks again!
09 Mar 2016 18:03
I like them too as long as they work.
10 Mar 2016 09:19....
You could install a manual fuel valve. search eebbaayy for yamaha raptor fuel valve [strike]44mm [/strike]or something like that.
super cheap are available, but I would get the made in Japan Yamaha part. ~$30. they come in a couple of versions, depending upon the year range. ...
Correction. I think the yamaha raptor fuel valve has a 34mm bole hole spacing. not sure if yamaha has one in 44mm.
- rstnick
10 Mar 2016 11:56
I use this Suzuki vacuum petcock on my 650c2.
The fuel feed is towards the back, so a longer fuel line is needed to route the fuel.
www.z1enterprises.com/product/KL18-4359
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- ezrider714
12 Mar 2016 18:08
For a 78 650C all you need is a 77 manual petcock direct bolt in, outlet same location looks just like stock
Have had this on my 78SR since 1983 when i tired of fixing the piece of junk vacuum stock one,was turned on to this by an old
Kaw racer/mechanic, Since then I have changed over 7 bikes(several 78650C's) with no problems. When I see a 76-77 manual petcock on ebay I buy it for future use :ohmy: Have yet to see a vacuum petcock worth a damn and it's just getting worse with the fuel blends being sold nowadays
78 KZ650SR Mine since 79
4-1 Mac Jet Hot coated since mid 80's
Dyna Coils
Saddlebags (I ain't skeered of going nowhere)
Dyna Coils
