Carb jetting advise
  • strum
  • strum's Avatar Topic Author
Carb jetting advise
02 Mar 2016 10:47 - 02 Mar 2016 10:48
#713451
Guys im still getting a very slight stumble at take off . It gets better as the bike warms but the plugs are black so i know its rich.
When i got the bike it had a lean condition (craking popping ect)
Now it runs beautiful at all ranges EXECPT start off.
I can pull the choke lever and it fires immediately and i can get off the choke pretty quick.
So Im running the 28mm pumpers and I know the sprays are spraying well.
17.5 pilots 117.5 mains stock air box Delvick header.
Air mixture screws about 3/4 out. thats the best i can get em if I come out anymore the stumble gets worse.
Idles great just that first little smidge when taking off it will stumble slightly.
Any thoughts from yall? Yes the valves are adjusted properly and the floats have been set using the clear tube method.
Blairsville Ga.
1980 KZ1000 Shaft (sold and missed already)
2003 ZRX 1200R (sold)
2003 Concours ZG1000 (just purchased)
Last edit: 02 Mar 2016 10:48 by strum.
  • strum
Re: Carb jetting advise
02 Mar 2016 16:01
#713514
thanks for the help guys :unsure:
Blairsville Ga.
  • SWest
  • SWest's Avatar
  • 10 22 2014
02 Mar 2016 16:06
#713517
CV carbs, air box etc?
  • strum
02 Mar 2016 17:44 - 02 Mar 2016 17:45
#713531
stock air box VM28mm pumper carbs. Delvic header
I think ive about decided my pilots are too big so Im gonna pull the carbs in a couple of days when im off and go down to a 15
at least that will answer that question.. I dont feel like i should have the air screws so far in. But thats where I get the lest stumble.
Blairsville Ga.
Last edit: 02 Mar 2016 17:45 by strum.
  • Nebr_Rex
  • Nebr_Rex's Avatar
02 Mar 2016 19:14
#713552
strum wrote: Guys im still getting a very slight stumble at take off . It gets better as the bike warms but the plugs are black so i know its rich.
Mains are to big.
Idle screws should be 1 1/4 out.
Stock cams? If so go back to 15s.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • strum
02 Mar 2016 19:30
#713554
thanks nebr_rex
I have some 115 mains . should i try them and the 15 pilots?
Blairsville Ga.
  • Nebr_Rex
  • Nebr_Rex's Avatar
02 Mar 2016 20:29
#713560
One change at a time.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • strum
03 Mar 2016 06:02
#713588
Nebr_Rex wrote: One change at a time.
Crap i knew you were gonna say that :laugh:
Ok Ill put the 15 pilots in and go from there.
Blairsville Ga.
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 Mar 2016 06:06
#713589
I ride 100 miles after a change to let things settle in, then move on if needed.
  • strum
03 Mar 2016 06:19
#713590
swest wrote: I ride 100 miles after a change to let things settle in, then move on if needed.
I agree i thought it was good as the plug color looked good to me after a short ride but after more riding they look black.. I think this gas dont turn the color as quick as it used too.
I did some WOT up hill tests and I dont get any indication that the mains are wrong .
If I go WOT then back off to 3/4 i have no speed up or stumble so thats what im looking for and all the mid range is good .
Blairsville Ga.
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 Mar 2016 06:22
#713591
I've set carbs rich only to have them lean out in time. If they're too rich, they'll wash out the rings and you'll lose compression, then dark plugs etc.
  • baldy110
  • baldy110's Avatar
03 Mar 2016 08:23
#713614
If you haven't done so also check your advance timing unit.
