mikuni bs34 carbs on a kz 650 jetting for elevatio
- sr650 rider
01 Mar 2016 15:26
Hello everyone recently moved from az to northern California I have a bs34 mikuni cv carb on my 78 650 Sr with a kerker 4 into 1 header and pods was curious to kno how much the elevation change will effect the jetting and if so what the proper jetting sizes are that I can use for replacement jets. Perhaps there is a graph based on elevation someone has Thank u in advance for your time and help
Re: mikuni bs34 carbs on a kz 650 jetting for elevatio
01 Mar 2016 16:36
What kind of elevation are we talking about?
01 Mar 2016 17:31 - 01 Mar 2016 17:31
Considering that you are running non-original carbs, plus the fact that they are CV carbs with pods, I doubt there's a jetting chart that will be applicable. I suspect you should plan to spend a good deal of time trying to get them to work as well as the stock VM24SS carbs would have worked with the stock airbox. Ed
Last edit: 01 Mar 2016 17:31 by 650ed.
The following user(s) said Thank You: sr650 rider
- baldy110
02 Mar 2016 08:48
If the bike was dialed in before you moved and we are not talking about 5000 feet or higher I wouldn't worry about.
