Tk22 carb Sync attempt, I'm out of my element.
  • MadShad
  • MadShad's Avatar Topic Author
28 Feb 2016 13:47
#712904
Tonight's project will be trying to snyc my carbs on my '81 GPz550.
I've read the manual, I've watched some videos, I have a rough idea of the principles at work here.
I have an auxiliary fuel tank, a 30 year old mercury manometer that has never been out of the box, a fan to keep the engine cool and about 6 hours to figure out what I'm doing.
I've been getting this bike sorted out with your help and put about 90 miles on it today and it runs and rides pretty good, it's not very happy at low idle and chugs and sputters at anything less than about 1300 rpm, I'm hoping this helps.
I'm open to advice, this will be my first time and I WILL be attempting this.
What say you?
Shelbyville, Indiana. '80 KZ1000
No more of that talk or I'll put the leeches on you, understand?
  • Olajoe
  • Olajoe's Avatar
  • Free at last
Re: Tk22 carb Sync attempt, I'm out of my element.
28 Feb 2016 13:49
#712905
go for it. after you've done it a few times, you may be able to do without the auxuliarry tank and just burn what's in the bowl, I mean the gas.
The following user(s) said Thank You: blackumi
  • SWest
  • SWest's Avatar
  • 10 22 2014
28 Feb 2016 13:54
#712908
A lot of carbs have a lead carb. #3 normally. Bench sync them and if not chose one and let it be. Adjust the rest to be even with it.
  • MadShad
28 Feb 2016 14:43
#712916
Well, that didn't take long to set up, here's where its at.
1234 right to left
  • SWest
  • SWest's Avatar
  • 10 22 2014
28 Feb 2016 14:47
#712918
Which is the lead carb? Should be left to right. :lol:
  • SWest
  • SWest's Avatar
  • 10 22 2014
28 Feb 2016 14:48
#712919
I'd have the fan close to the engine.
  • MadShad
28 Feb 2016 15:00
#712926
Yep I meant left to right :side:
Not sure in the lead carb, i had 2 that were close so I just adjusted the others to match.
  • loudhvx
  • loudhvx's Avatar
28 Feb 2016 15:54
#712935
Looks good.
There is no lead carb on the TK22's.
  • SWest
  • SWest's Avatar
  • 10 22 2014
28 Feb 2016 15:55
#712937
How's your idle? Bet the noises went away. :whistle:
  • KZB2 650
  • KZB2 650's Avatar
28 Feb 2016 16:29
#712951
loudhvx wrote: Looks good.
Ha you and me are on the same page tonight ..... just spent the last 20-25 minutes looking this up and the 5 clutch springs vs 6 too in your exc manual down loads. :laugh:
Also I always wondered .... the manual states 19 to 24 cm? or what ever it is so I always tryed to shoot for around 21 and a half or so ..... does this make a difference to be on the low end or the high ??
Good job on the sync Madshad too you got it done quick and right on the money.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • MadShad
28 Feb 2016 16:56
#712963
swest wrote: How's your idle? Bet the noises went away. :whistle:
It sure is nice when things go the way they should.....
Whole different bike at Idle and right off the line, cold start is much better.
Idle rpm is set at 1 needle width above the 10 on the tach and is rock solid.
The hardest part about the whole thing was making my brother look for his new in the box motion pro manometer that he stuffed away 30 years ago.
  • SWest
  • SWest's Avatar
  • 10 22 2014
28 Feb 2016 17:01
#712967
B)
