Pilot jet ?
  • Wyliecoyote
  • Wyliecoyote's Avatar Topic Author
Re: Pilot jet ?
27 Feb 2016 18:41
#712773
Yes the air fuel mix screws r new as well as the o rings, jets r fairly inexpensive so I'll prolly do that. Are there any good pod style filters out there I liked the uni foam filters on other bikes I've had.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Pilot jet ?
27 Feb 2016 18:45
#712774
I'm sure others here will be more helpful there. K&N's are a good choice.
Re: Pilot jet ?
27 Feb 2016 19:48 - 27 Feb 2016 19:53
#712784
It's good to see that valve clearances are all within spec.
If not already done before attempting to determine the best performing pilot jet size, would also want to assure that all fuel levels are within spec as shown by the clear tube test.
Presumably, compression is adequate in all cylinders, spark is strong on every plug and correctly timed, and all pilot circuit passages are as-new clean.
Good Fortune! :)
Last edit: 27 Feb 2016 19:53 by Patton.
  • Wyliecoyote
Re: Pilot jet ?
06 Mar 2016 08:52
#714119
So to update, I have done clear tube float hight test. I put in the 22.5 pilot jets it runs good plugs look the same so I've ordered 122.5 mains I'll try next week. I'm happy with the way it runs put plugs still don't pass the eye test . I'm wondering how much if any the electronic ignition effects the jetting by means of making it run hotter..anyho I'll keep plug chopping away...lol. It's gotta be close just based on performance!
