Pilot jet ?
- Wyliecoyote
Pilot jet ?
18 Feb 2016 17:32
Are the 26 and 28 mikuni pilot jets interchangeable? I found some on eBay they look the same but it says they are for vm28 but I have vm26 on my bike..thx for any input!
Re: Pilot jet ?
18 Feb 2016 17:34
Yes they are.
The following user(s) said Thank You: Wyliecoyote
- Wyliecoyote
Re: Pilot jet ?
18 Feb 2016 18:44
The slides are the same too.
- missionkz
Re: Pilot jet ?
18 Feb 2016 20:35does that mean you could bore the throttle bodies out to 28mm or more?swest wrote: The slides are the same too.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Re: Pilot jet ?
18 Feb 2016 20:41
I guess you could but why? I took the KZ 900 carbs apart for the slides and floats. Looking back on it that was stupid. Who knew they would be worth money now.
- GregZ
Re: Pilot jet ?
19 Feb 2016 00:31missionkz wrote:does that mean you could bore the throttle bodies out to 28mm or more?swest wrote: The slides are the same too.
Once in a while you will see a set of 28's bored to 29, still not same as a nice set smoothbore's though
- Wyliecoyote
Re: Pilot jet ?
27 Feb 2016 17:46 - 27 Feb 2016 17:48
So I put went from 17.5 to 20 pilot jets and it comes off the line much better, it actually feels really good all the way through the gears. My settings are kz1000 vm26, v and Hines street pipe, cheapo pods, #120 mains #20 pilot, 4th clip from top on needle, 2 turns out + or - 1/4 turn. The thing is the cyl 1 plug looks light tan on the inside ( looks nice) 2,3,4 still looking too whitish grey to me still to lean but runs really well. Velves are set properly all between .05 & .10mm. Has dyna elec iggy. Prolly makes it leaner also. So my next move is to sync the carbs. I'm at altitude here in Denver Suberb. Anyway just an update I know it's tough to advise but any input is welcome. Thx
Last edit: 27 Feb 2016 17:48 by Wyliecoyote.
Re: Pilot jet ?
27 Feb 2016 18:07
Pics of the plugs?
- Wyliecoyote
- Wyliecoyote
Re: Pilot jet ?
27 Feb 2016 18:32
Does the air screw work well? Might go 22.5 and 125 main jets .
