Tk22 carbs
  • Jbruno08
  • Jbruno08's Avatar Topic Author
Tk22 carbs
01 Feb 2016 02:20
#708832
So I want to go with straight pipes but can't find a jet kit anywhere for an 83 kz550 ltd c4. I need advice on how to up the jets and how to remove the baffles. It does have the stock air box and I'm going to keep it that way. Thanks in advance.
  • rrsmsw9999
  • rrsmsw9999's Avatar
Re: Tk22 carbs
01 Feb 2016 03:04
#708836
gpzweb.s3-website-us-east-1.amazonaws.co...ge/TK22mainPage.html
Alot of great 550 info there from member Loudhvx
I believe you need a jet kit as that is the only supply of larger jets. Another option is drilling them. Check out Loudhvx site info on the 550 models.
R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
  • Jbruno08
Re: Tk22 carbs
01 Feb 2016 06:24
#708866
I can not find any jets for my year and model. Will any others fit?
  • baldy110
  • baldy110's Avatar
Re: Tk22 carbs
01 Feb 2016 07:39
#708874
Parts for the TK22 carbs are very hard to come by and you will not find any jet kit for those.
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • rrsmsw9999
Re: Tk22 carbs
01 Feb 2016 09:12
#708893
The kit is Dynojet Kit DJ-2305, or just #2305 .
The same kit is also available under the K & N brand. It is K & N kit 81-9012.
R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
  • loudhvx
  • loudhvx's Avatar
Re: Tk22 carbs
01 Feb 2016 18:37
#708963
You can readily get stock size jets for the TK22 in the rebuild kits, and new needles and main jets from the Dynojet kit R mentioned.
The info is also in that link R posted.
I have recently rejetted a TK22 equipped KZ550, with no airbox, using the stock jets and simply shimming the factory needle precisely. It runs perfectly, but may be slightly richer than ideal for getting high gas mileage. But it's nice to be able to use the stock jets.
The details for shimming are on the TK22 page.
I would start with a .3 to .5mm shim, (and whatever shim wire is required).
But all of that is going to be the last step after confirming the compression and valve clearance, ignition timing and consistency etc. Then fuel level, sync etc.
  • loudhvx
  • loudhvx's Avatar
Re: Tk22 carbs
01 Feb 2016 18:39 - 01 Feb 2016 18:39
#708964
Jbruno08 wrote: I can not find any jets for my year and model. Will any others fit?
KZ550 (80-82 A1-A3), and (80-83 C1-C4) all came with the same carbs...TK22.
Details are on the tk22 site.
Last edit: 01 Feb 2016 18:39 by loudhvx.
The following user(s) said Thank You: Jbruno08
  • jdvorchak
  • jdvorchak's Avatar
Re: Tk22 carbs
03 Feb 2016 05:32
#709167
In my opinion you don't need to re-jet if just changing the exhaust. I'd put the straight pipes on and see how it runs. You may not need any changes to mixture.
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
