Another 1000st airbox question
  • strum
  • strum's Avatar Topic Author
24 Jan 2016 13:25
#707913
As i search the forum for airbox info im finding little on these.
Mine has the lower silencer part but the elbow snorkle or whatever you call it is gone.
I think i read some where to remove the lower part and even the screens to improve performance.
I know i know ..if it aint broke dont fix it ..
But i have to know lol. will it get more air ..will it sound different
i have no problem re jetting if is does get more air.
Blairsville Ga.
1980 KZ1000 Shaft (sold and missed already)
2003 ZRX 1200R (sold)
2003 Concours ZG1000 (just purchased)
Re: Another 1000st airbox question
24 Jan 2016 13:29
#707914
So what do you plan to do about filtering the air? Sucking in air that has fine road grit, etc. in it is going to kill, not improve, performance because it will quickly grind up the cylinder walls / piston rings which in turn will ruin your compression. Ed
  • Nebr_Rex
  • Nebr_Rex's Avatar
24 Jan 2016 14:24
#707921
650ed wrote: So what do you plan to do about filtering the air? Sucking in air that has fine road grit, etc. in it is going to kill, not improve, performance because it will quickly grind up the cylinder walls / piston rings which in turn will ruin your compression. Ed.........
Ed you know not of what you speak. The Kz1000st has the air filter in the first section behind carbs.
Removing the curved snorkel will have little effect on performance or jetting. I ran just the first section with
a replacement K&N filter until I sold the bike this last fall. Now the hole there is bigger and does require
some carb tuning.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Jan 2016 14:56
#707927
I have never used the silencer on my air box. Too restrictive and stupid. :whistle:
24 Jan 2016 14:59 - 24 Jan 2016 15:03
#707928
some carb tuning.
This is probably true; it wouldn't be the first time. However, he stated "I think i read some where to remove the lower part and even the screens to improve performance" If he does that what would filter the air? Ed
Attachment 00003e-8.jpg not found
Last edit: 24 Jan 2016 15:03 by 650ed.
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Jan 2016 15:04
#707931
Yes, no wonder they were so slow.
  • strum
24 Jan 2016 15:43 - 24 Jan 2016 15:46
#707936
Ed the screens dont filter the air ..the air filter does ..right..
but that said i am not to keen on removing them. and im not too sure i want to fool with it at all just wondering what some of you guys have done in the past.and im still not sure what the lower part does and does it restrict air?
Blairsville Ga.
Last edit: 24 Jan 2016 15:46 by strum.
  • strum
24 Jan 2016 15:50 - 24 Jan 2016 16:07
#707939
Ed i see your point..we just talking baout two different things,,the diagram doesnt really show it but parts 5&6 have a mesh on them that im thinking the articular I read was talking about removing. since i have looked in a few airboxes and saw large bugs and other things i can see why these need to stay in place.
Blairsville Ga.
Last edit: 24 Jan 2016 16:07 by strum.
  • strum
24 Jan 2016 15:51
#707940
swest wrote: Yes, no wonder they were so slow.
Steve!! :laugh: :laugh: :laugh: :laugh:
Blairsville Ga.
  • Nebr_Rex
  • Nebr_Rex's Avatar
24 Jan 2016 16:01
#707942
They weighed almost 600 lbs.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • strum
24 Jan 2016 16:06
#707943
just so yall know you have called it slow and fat. you should be ashamed :laugh:
Blairsville Ga.
  • floivanus
  • floivanus's Avatar
24 Jan 2016 16:09
#707944
To my knowledge there hasn't been an actual dtno/driving test or REAL (not sponsored by a speed shop or parts place) checking the difference between having a snorkel and not, it was designed that way for a reason, the screens barely obstruct anything and the snorkel helps drivability.
The elbow? I have one of them in the parts shed, buried behind the H2 motor I'll be moving in a few hours
Past; 78 kz1000, 83 kz550
Andrew
