- Thank you received: 7
Loose fuel inlet tee
- strum
the fuel inlet tee and the crossovers are very loose. Im sure this has been asked before ..lol maybe even by me..but
i got a used set from ebay and the seller said the rubber is fine but I may want to use something like Hylamar Blue on em..
the crossovers actually fit tighter than the ones i have but the tee is about the same..loose.. i tried heating one up with a heat gun and it did fit tighter but im still not sure itll work ..so I have it soaking in a transmission/brake fluid mixture.
any thoughts on this ? you cant put orings on these. and what about the Hylamar Blue method?..waste of time?.
will they swell up when i start using them?
Blairsville Ga.
1980 KZ1000 Shaft (sold and missed already)
2003 ZRX 1200R (sold)
2003 Concours ZG1000 (just purchased)
- strum
Blairsville Ga.
- DFIGPZ
- Thank you received: 122
- strum
DFIGPZ wrote: get the aluminum tee's from Z1E
I looked at those and i dont think they will fit..it says overall length 40mm thats 1.5748" .. mine is 2.325"
i think theirs are for the older 28 and 26 carbs.
Blairsville Ga.
- baldy110
- Thank you received: 512
- pete greek1
- Thank you received: 185
get the yellow Teflon tape for gas plumbing , it's thicker than the white & probably more impervious to the fuelbaldy110 wrote: Very easy and cheap fix, wrap regular old Teflon tape around all the ends and insert. Make sure they are all a very snug fit. works great and will last.
Pete
- Thank you received: 1656
My mistake. this one looks too short. doh.
for future reference search tag aluminum fuel tee
- strum
Pete
im not opposed to this at all but i still want to figure out how to swell the rubber.
i have seen concoctions using wintergreen and acetone i think..
Blairsville Ga.
- bluej58
- Thank you received: 511
they have since held for 4 years and over 30,000 miles.
So I say soak them in gas for a couple days and see if they feel tighter.
78 KZ1000 A2A
- Thank you received: 2755
- kaw-a-holic
- Thank you received: 249
I know this is not the right part but you can use this link if you wanted to contact the seller.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
- strum
kaw-a-holic wrote: I bought the replacement aluminum ones off eBay from a guy in Belgrade MT. You might be able to contact him and see if he has a set for your 28's.
thanks man ..i followed the seller and look what i found!! Im going to continue to soak mine but i think this is the route ill ultimately go.
Blairsville Ga.
