Loose fuel inlet tee
  • strum
  • strum's Avatar Topic Author
22 Jan 2016 08:56 - 22 Jan 2016 09:01
#707624
I got this set of 28 pumpers from ebay and i got em all cleaned up and assembled.
the fuel inlet tee and the crossovers are very loose. Im sure this has been asked before ..lol maybe even by me..but
i got a used set from ebay and the seller said the rubber is fine but I may want to use something like Hylamar Blue on em..
the crossovers actually fit tighter than the ones i have but the tee is about the same..loose.. i tried heating one up with a heat gun and it did fit tighter but im still not sure itll work ..so I have it soaking in a transmission/brake fluid mixture.
any thoughts on this ? you cant put orings on these. and what about the Hylamar Blue method?..waste of time?.
will they swell up when i start using them?
Blairsville Ga.
1980 KZ1000 Shaft (sold and missed already)
2003 ZRX 1200R (sold)
2003 Concours ZG1000 (just purchased)
Last edit: 22 Jan 2016 09:01 by strum.
  • strum
Re: Loose fuel inlet tee
22 Jan 2016 09:23
#707628
heres a thought..I found a couple of o rings that slid over the tee and slapped it in ..once i mounted the carbs on the rail the tee is very snug..not sure if it will work but its an effort. im going to soak the other one for a day or two and see what happens but i think in a pinch this method with a dab of grease may get me by
Blairsville Ga.
  • DFIGPZ
  • DFIGPZ's Avatar
22 Jan 2016 09:28
#707629
get the aluminum tee's from Z1E
1984 750 Turbo
  • strum
22 Jan 2016 09:39
#707631
DFIGPZ wrote: get the aluminum tee's from Z1E
I looked at those and i dont think they will fit..it says overall length 40mm thats 1.5748" .. mine is 2.325"
i think theirs are for the older 28 and 26 carbs.
Blairsville Ga.
  • baldy110
  • baldy110's Avatar
22 Jan 2016 11:12
#707641
Very easy and cheap fix, wrap regular old Teflon tape around all the ends and insert. Make sure they are all a very snug fit. works great and will last.
  • pete greek1
  • pete greek1's Avatar
22 Jan 2016 11:23
#707642
baldy110 wrote: Very easy and cheap fix, wrap regular old Teflon tape around all the ends and insert. Make sure they are all a very snug fit. works great and will last.
get the yellow Teflon tape for gas plumbing , it's thicker than the white & probably more impervious to the fuel
Pete
  • martin_csr
  • martin_csr's Avatar
22 Jan 2016 11:27 - 23 Jan 2016 05:51
#707644
[strike]Z1Enterprises.com --- Fuel Pipe Joint Kawasaki --- 16046-002[/strike] ....... ...... edit: alum tee
My mistake. this one looks too short. doh.
for future reference search tag aluminum fuel tee
Last edit: 23 Jan 2016 05:51 by martin_csr.
  • strum
22 Jan 2016 12:02
#707648
Pete
im not opposed to this at all but i still want to figure out how to swell the rubber.
i have seen concoctions using wintergreen and acetone i think..
Blairsville Ga.
  • bluej58
  • bluej58's Avatar
22 Jan 2016 12:11 - 22 Jan 2016 12:12
#707649
Mine leaked after sitting for 20 years unused but swelled back up after being reintroduced them to fresh gas.
they have since held for 4 years and over 30,000 miles.
So I say soak them in gas for a couple days and see if they feel tighter. ;)
78 KZ1000 A2A
Last edit: 22 Jan 2016 12:12 by bluej58.
  • SWest
  • SWest's Avatar
  • 10 22 2014
22 Jan 2016 12:28
#707655
Use grease to put them in.
  • kaw-a-holic
  • kaw-a-holic's Avatar
23 Jan 2016 02:49 - 23 Jan 2016 02:49
#707702
No eBay APP ID and/or Cert ID defined in Kunena configurationI bought the replacement aluminum ones off eBay from a guy in Belgrade MT. You might be able to contact him and see if he has a set for your 28's.
I know this is not the right part but you can use this link if you wanted to contact the seller.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
Last edit: 23 Jan 2016 02:49 by kaw-a-holic.
  • strum
23 Jan 2016 04:49
#707709
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
kaw-a-holic wrote: I bought the replacement aluminum ones off eBay from a guy in Belgrade MT. You might be able to contact him and see if he has a set for your 28's.
thanks man ..i followed the seller and look what i found!! Im going to continue to soak mine but i think this is the route ill ultimately go.
Blairsville Ga.
