kz400 Dual to single outlet petcock swap
- padgett
20 Jan 2016 09:24
I have a gravity fed petcock on there that is dual outlet, but one of the outlets is loose and leaking terribly. Would there be any danger in just closing off (jb weld) that leaky spout and running a single fuel line from the petcock to the carbs?
Thanks
Thanks
Re: kz400 Dual to single outlet petcock swap
20 Jan 2016 11:25
What year is your KZ400? Does it have a manual fuel valve or a vacuum petcock?
You might be able to repair the leak. The fuel port on my 81 650 got pulled out, so I re-sealed it with Permatex liquid metal. I also used the stuff to repair a leaky low fuel switch. Seal-All would be another product that should work (Lowes or HomeDepot).
- padgett
20 Jan 2016 11:27
its a 74 but a mishmash of parts.
The petcock I have does not have a vacuum. Its just the two spouts coming straight out for fuel. So if I removed the one spout i'd starve for fuel probably?
- floivanus
20 Jan 2016 13:13
Probably not, but if you are sealing with epoxy any way, pull the tube out, smear the epoxt around the tube (keep it off the very tip of the tube) and stick it back in the hole. That will keep your dual outlet setup like it is now
Past; 78 kz1000, 83 kz550
Andrew
Andrew
- Nelson
20 Jan 2016 14:19
have u taken it apart? no chance of a repair? I was able to stop the leaks on mine by bending the wavy washer (spring) so it puts more pressure on the rubber thing.
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
- padgett
20 Jan 2016 14:21
yea had it apart, but its leaking from the outlet itself, the brass is loose,
21 Jan 2016 02:09 - 21 Jan 2016 02:11
A leaky fuel valve port isn't uncommon. an epoxy repair is a simple fix. I did mine several years ago.
Last edit: 21 Jan 2016 02:11 by martin_csr.
- jdvorchak
23 Jan 2016 05:00martin_csr wrote: A leaky fuel valve port isn't uncommon. an epoxy repair is a simple fix. I did mine several years ago.
+1 I've repaired them with JB Weld but epoxy would work as well. Try not to tear it up pulling the brass nipple out.Gentle twisting and pulling should free it.
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
John
83 KZ550M1
83 KZ1100LTD
Also own:
- jdvorchak
23 Jan 2016 05:04
Just had another thought. If you put some fuel line on that fitting with a tight screw type clamp you can use your pliers on the rubber hose for twisting and pulling and not touch the brass part. If it doesn't pull right out I'd also use my heat gun to heat the aluminum part.
John
83 KZ550M1
83 KZ1100LTD
Also own:
John
83 KZ550M1
83 KZ1100LTD
Also own:
- Nelson
23 Jan 2016 07:06
that's a great idea! the rubber hose becomes sorta like a strap wrench.
- pete greek1
23 Jan 2016 07:47
When I had that problem I just cleaned the area around the nipple without removing it, & just put a bead of JB Weld around where the nipple inserts into the petcock, & it never leaked again
Pete
Pete
- jdvorchak
23 Jan 2016 19:23 - 23 Jan 2016 19:24pete greek1 wrote: When I had that problem I just cleaned the area around the nipple without removing it, & just put a bead of JB Weld around where the nipple inserts into the petcock, & it never leaked again
Pete
That could work. I'd make sure I used JB Weld not JB Quick. JB Weld seems to hold up better in the presence of gasoline. If the brass tube doesn't come out easily I'd try a bead of JB Weld.
John
83 KZ550M1
83 KZ1100LTD
Also own:
John
83 KZ550M1
83 KZ1100LTD
Also own:
Last edit: 23 Jan 2016 19:24 by jdvorchak.
