Larger pilot jets for kz750e?
- runmikeyrun
05 Jan 2016 08:02
Hi guys, dealer told me that only Kawasaki makes my pilot jet and it's unavailable. eBay yields few results, each priced at $20. Does anyone make these and sell separate from a kit?
Thanks,
Mike
Thanks,
Mike
Monkey? MONKEY? I'm a GORILLA you CLOWN!
Re: Larger pilot jets for kz750e?
05 Jan 2016 10:58
Z1 Enterprises sells jets for those bikes. They are having issues with their website lately though so you may have to call them. Typically you don't need to mess with the pilot jets, even when installing pods. Dynojet provides new main jets and needles in their Stage 1&3 kits for those bikes, not pilot jets.
- runmikeyrun
05 Jan 2016 11:01
I will look into that, thank you. Right now I have pods and Kerker 4-1. Pilots were 5 turns out and bike popped a lot at idle and some on decel. I'm not sure how many more turns out I can go! I think I'm going to check the passages and drop the jets into some cleaner before spending money on them.
- undiablo
05 Jan 2016 13:29
JetRUs sells #38 pilots.
Make sure you clean the off idle transition ports, behind the butterfly.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- jertho
05 Jan 2016 18:29
Dennis kirk has pilot jets.
Jerry
Jerry
1978 kz750 twin
05 Jan 2016 18:32
Checked your carb holders?
- jdvorchak
07 Jan 2016 19:18
Just my opinion but any more than 4 turns out and you need bigger jets.
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
John
83 KZ550M1
83 KZ1100LTD
Also own:
- ThatGPzGuy
08 Jan 2016 01:45
3.5 turns is the usual rule-of-thumb before you go up in pilots. But like the others say make sure there are no restrictions anywhere first.
Oh, and your dealer is an idiot. Stay away.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- undiablo
08 Jan 2016 03:08
I have an extra set of 4 Keihin CV34 #35 slow pilot jets that I am planning to drill to #40. I will post results when I get there.
- runmikeyrun
08 Jan 2016 06:05
Hey guys, thanks for the responses. I ended up cleaning the passages really well, there was a little bit of junk in two of them. I've read that even with pods the screws should only be two turns out. That doesn't seem like enough. I agree that anything more than 3.5-4 out needs next size up. I'm going to set them at 3 and start there. I won't be able to test for a while as the gas tank is currently being prepped for paint. I appreciate the help!
The following user(s) said Thank You: undiablo
- undiablo
08 Jan 2016 08:14
please keep us posted.
- floivanus
08 Jan 2016 10:25runmikeyrun wrote: I won't be able to test for a while as the gas tank is currently being prepped for paint. I appreciate the help!
Whip up a temp fuel tank (good for carb syncing as well, a length of pvc pipe with a screw on cap on one side and a cap with a drilled hole and a pressed in hose works, zip tie to the backbone and go for a quick test ride.
I've also used a pop bottle for carb sync, but you wouldn't have quite the range with that.
Past; 78 kz1000, 83 kz550
Andrew
Andrew
