Rpms jump around
  • VegasRob
  • VegasRob's Avatar Topic Author
  • 81 Kz750
Rpms jump around
02 Jan 2016 17:06
#705342
Hello to the awsome folks on the KZR forum. I find myself here again in need of some guidance. A few weeks ago I got some excellent help correcting a no spark condition on my recently purchased 81 kz750. The spark issue is resolved and now I find myself embarking into the wonderful world of carbs.
The issue is that my rpms will not remain consistant. The bike will start up without any problem. I have the idle set at around 1800. After a few minutes the idle will drop to about 1k or shoot up to 4k completely randomly. Blipping the throttle usually brings the rpms back to 1800. I recently took the bike for a short first ride down my street, (my first time on a bike) and I'm just keeping it easy in first gear just to feel out the clutch, when the rpms start to run up without any throttle input. I'm new but I'm pretty sure something isn't right.
A little info on my bike, it is a 1981 kz750e 4cyl. It isn't a stock setup. It has the air box removed and the keihin carbs are set for pod filters. Idle jet has been bumped up a size. It currently has a fuel leak at the tee inlet. I have a new one on order but j b weld is helping that out until the part arrives. I also found out while working on my spark issue that my bike has a points style ignition out of a 68. Also the carbs were just cleaned, everything appears to be in good working order except for the rpm problem.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Rpms jump around
02 Jan 2016 17:24
#705348
Carb holders at the engine. You mean 78 don't you? :unsure:
  • VegasRob
  • 81 Kz750
02 Jan 2016 17:38
#705351
I bought the bike from a guy in the middle of a cafe racer project. The bike is an '81, but it does have the fuel tank and rear section from a '78 I think. It has a collection of parts to make my life simple.
Will a Crack in the carborators mounting boots cause a problem like the one I'm dealing with? I didn't notice any cracks but I might need to make a closer inspection.
  • SWest
  • SWest's Avatar
  • 10 22 2014
02 Jan 2016 17:59
#705352
They get hard and crack where they bolt onto the head. You can't see it and it doesn't take much.
  • VegasRob
  • 81 Kz750
02 Jan 2016 18:10
#705354
Thanks, I'm going to take a closer look.
I forgot to mention that all of the vacuum lines are removed and the ports are plugged, the breathers on the forward valve cover have the hoses removed with small air filters installed. I don't know if that makes any difference. The fuel tank has just a simple on/off petcock with gravity feed to the carbs. No vacuum operation.
  • SWest
  • SWest's Avatar
  • 10 22 2014
02 Jan 2016 18:17
#705355
Those aren't breathers. Connect the two with a hose for now.
  • VegasRob
  • 81 Kz750
02 Jan 2016 18:20
#705356
What does that do? I suspect it was part of some emissions or something.
  • SWest
  • SWest's Avatar
  • 10 22 2014
02 Jan 2016 18:24
#705357
With all the other hoses, they inject air into the exhaust ports. If you don't have the air box or the plumbing, they need to be blocked off.
  • Mean Green Z28
  • Mean Green Z28's Avatar
  • Kawasaki NooB
Re: Re:Rpms jump around
02 Jan 2016 18:25
#705360
VegasRob wrote: What does that do? I suspect it was part of some emissions or something.
Yeah it was routed back into the airbox through a vacuum operated valve.
Take some ether or braklean and spray around the carb/boot area while the bike is idling. You'll def hear the rpms rise if there's a leak. That's how I found that my throttle shafts seal was still leaking even after I replaced that he boots !
2010 Camaro 2SS
1983 Kawi KZ1000P ... bag of bolts
  • VegasRob
  • 81 Kz750
02 Jan 2016 18:28
#705361
Okay, I'll round up some hose and link them together. Should I be on the hunt for the stock stuff or is plugging them sufficient. What kind of trouble can this cause?
  • SWest
  • SWest's Avatar
  • 10 22 2014
02 Jan 2016 18:37 - 02 Jan 2016 18:37
#705362
I'd go with the air box. The rest can stay off. Pics?
Last edit: 02 Jan 2016 18:37 by SWest.
  • VegasRob
  • 81 Kz750
02 Jan 2016 18:44
#705364
Here's some pics
