Mikuni Kogyo Carb identification
  • DFIGPZ
  • DFIGPZ's Avatar
Re: Mikuni Kogyo Carb identification
13 Dec 2015 12:05
#702982
I do not understand why people think they will not work on o 650 ? Way back in the 80's I did a KZ650 for a customer 720 wiesco kit street cams lightly ported head and a set of 29 Mikuni smoothbores and it ran and idled flawless like 900 rpm and I do not remember doing much to them :S
1984 750 Turbo
  • zukdave
  • zukdave's Avatar
13 Dec 2015 12:30
#702987
They can work work on a small motor if you spend the time to tune them.
I think for the avg. home mechanic they can be a pain,
With mine I think my issue is they need larger idle air bleed jets but since I want a more
modern carb. like a flat slide or the CR special so I'm done with them.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
13 Dec 2015 12:48 - 13 Dec 2015 12:49
#702992
DFIGPZ wrote: I do not understand why people think they will not work on o 650 ? Way back in the 80's I did a KZ650 for a customer 720 wiesco kit street cams lightly ported head and a set of 29 Mikuni smoothbores and it ran and idled flawless like 900 rpm and I do not remember doing much to them :S
You may have answered your own question. As you described it, the engine you put them on was not stock. If it had been a stock KZ650 engine you may have had different results. Ed
Last edit: 13 Dec 2015 12:49 by 650ed.
  • floivanus
  • floivanus's Avatar
13 Dec 2015 12:49
#702993
zukdave wrote: They can work work on a small motor if you spend the time to tune them.
That's my feeling on the smoothbores, outdated old tech that is way overpriced, a set of newer sportbike carbs are an upgrade, newer mikuni designs or CR carbs are also. Yet for the money you could piece together an EFI setup and have instant reliable tuning
Past; 78 kz1000, 83 kz550
Andrew
13 Dec 2015 12:53
#702994
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
  • kawasakisubaru
  • kawasakisubaru's Avatar Topic Author
13 Dec 2015 13:01
#702996
Thanks for all this info, I'm learning a shit ton about these carbs/how they work and it seems the most cost effective plan as of now is to buy larger main jets and pilot jets. Assuming factory jets, what sizes would I need to smooth out the idle?
(Good gas mileage would be nice but fuck it, I didn't buy a motorcycle 11 years older than myself to be economical)
1980 KZ750 E1
Kerker by Kawasaki 4-1 exhaust
Lockhart oil cooler
Mikuni VM29 smoothbore carbs
Pingel high flow petcock
Dunlop K70s
Custom brat style seat
Clubman bars
Dime city cycles 1.5in tach/speedo
Ox blood grips
  • zukdave
  • zukdave's Avatar
13 Dec 2015 13:18
#703002
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • floivanus
13 Dec 2015 13:38
#703007
  • 750Kruzer
  • 750Kruzer's Avatar
13 Dec 2015 14:05 - 13 Dec 2015 14:07
#703012
What does the "BS" & "CV" designations stand for?
floivanus wrote: Honestly, I don't really understand the hype, back in the 70's when they came out the 29s were a great carb. Today, there are very few bikes that come with mechanical carburetors, CV carbs dominate the market, even on crotch rockets etc. well, that is, before EFI.
$600 seems to be real world top dollar for smoothbores. Someone once in a while may get more, but it's not typical
1983 KZ750 LTD Twin K1
Last edit: 13 Dec 2015 14:07 by 750Kruzer.
13 Dec 2015 14:06 - 13 Dec 2015 14:07
#703013
floivanus wrote: "Seems $500-600 is the midrange for them."
Agree. Ed
Last edit: 13 Dec 2015 14:07 by 650ed.
  • floivanus
13 Dec 2015 14:17
#703016
CV carbs are controlled by vacuum signal from the engine, they work much like the old quadrajet or edelbrock carbs.
You may crank the theottle wide open, but if the engine only needs 3/4 throttle the slide only really moves 3/4 of the way, reducing bogging, increasing gas mileage and performance. If you look at motorcycles, minus the aftermarket performance carbs, the mechanical slide type carbs basically disapeared in the 1980s and were replaced with CV carbs.
BS carbs are a subset of mikuni carbs that came on KZ and GS suzuki models. I.e; BS34 carbs on kz1000s after 1981.
Andrew
The following user(s) said Thank You: 750Kruzer
  • Nessism
  • Nessism's Avatar
13 Dec 2015 14:19 - 13 Dec 2015 14:20
#703017
750Kruzer wrote: What does the "BS" & "CV" designations stand for?
CV = constant vacuum.
BS is Mikuni's designation for a family of CV carbs from back in the KZ era. BS34's for example are 34mm CV carbs.
Edit: looks like two of us posted at the same time. :side:
Last edit: 13 Dec 2015 14:20 by Nessism.
