Fuel enricher CV Carbs
  • razmo99
  • razmo99's Avatar Topic Author
23 Nov 2015 18:04
#700211
Just wondering if this is correct behaviour for cv carbs
The carbs in question are cvk34 carbs
When the bike is warm and the choke is pulled the rpms will rise, at full choke the bike will max out at 5k rpm
Is this normal? or should the bike die out from too much fuel/
- Z500 B4
-GPZ900R A9-10 ish
  • Nessism
  • Nessism's Avatar
  • undiablo
  • undiablo's Avatar
Re: Fuel enricher CV Carbs
24 Nov 2015 02:28
#700250
Why would you want to use the choke with a warm engine?
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
  • GPzMOD750
  • GPzMOD750's Avatar
24 Nov 2015 02:34
#700251
All is good.
  • Tyrell Corp
  • Tyrell Corp's Avatar
24 Nov 2015 07:40
#700296
yes, one of those kz gpz quirks one gets used to. I prefer to pull away just after starting and knock the choke off, or 1/2 depending on the weather. It will be grumpy until a mile later - you don't want to thrash these anyway when cold. The slide carbs 'choke' are bad for this too,certainly on the 550's.
  • razmo99
24 Nov 2015 10:54
#700334
Ok thats good to know.
- Z500 B4
-GPZ900R A9-10 ish
