Cylinders 2 and 3 running rich
- redhawk4
Re: Cylinders 2 and 3 running rich
18 Nov 2015 17:38
If all else fails you could try swapping the coils over to see if the problem goes to the other two cylinders.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
1977 KZ650B1
1980 Suzuki SP400
- JDRAKE4200
19 Nov 2015 10:42
Checked coils... 3.3 and 3.4 ohms. Forget the numbers on the secondary but both were above 10k.
Valves are good as I just checked them while the bike was apart.
So, the fuel screws on the bottom of the carb.... Screw in to lean it out?
Keep the shiny side up!!!!
1976 KZ900 LTD
2004 Sportster 1200 Custom
1981 KZ550 LTD
1994 GSXR 750
1976 KZ900 LTD
1981 KZ550 LTD
1994 GSXR 750
- jdvorchak
19 Nov 2015 12:43
Rule of thumb if the mixture screw is on the air cleaner side of the slide then it's air and screw in to rich (less air) or out to lean (more air). If the mixture screw is on the engine side it's fuel. So screw in to lean mixture and screw out to richen.
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
John
83 KZ550M1
83 KZ1100LTD
Also own:
- jdvorchak
19 Nov 2015 12:51
One other thing I do when checking coils is to measure resistance between the spark plug wire connectors (where they plug onto the spark plugs). Then I'll measure the resistance between the towers of the coil. That way you are checking end to end. And finally each wire individually looking for a balance.
John
83 KZ550M1
83 KZ1100LTD
Also own:
John
83 KZ550M1
83 KZ1100LTD
Also own:
- redhawk4
19 Nov 2015 12:59JDRAKE4200 wrote: Checked coils... 3.3 and 3.4 ohms. Forget the numbers on the secondary but both were above 10k.
If the screws are on the bottom at the front they are "fuel screws" as opposed to "air screws" The further out they are the more fuel is allowed around that circuit. While these screws effect mixture at idle, I don't think they have much effect once you are up and running with some rpm on and throttle applied, so while they could make your plugs black at idle, I don't know that they would overall. Having said that they need to be set anyway.
1977 KZ650B1
1980 Suzuki SP400
1977 KZ650B1
1980 Suzuki SP400
- KZB2 650
20 Nov 2015 05:15
Wonder if you outta check the volts going to each coil.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
20 Nov 2015 05:38
Yup, they get their power from one connector. If it's dirty, you can have problems.
20 Nov 2015 05:41
I ran a relay bypassing the 40 year old switches. Same problem with my new HID headlight. Wouldn't work until they sent me a relay and I installed it.
- redhawk4
20 Nov 2015 06:12
I still think swapping the coils from side to side to see if the problem follows the change, is the best way to eliminate the possibility of an issue with the actual coils them selves.
1977 KZ650B1
1980 Suzuki SP400
1977 KZ650B1
1980 Suzuki SP400
20 Nov 2015 06:29
You're right about that.
