carb bowl drip still....
- blink543
06 Nov 2015 05:41
I had my carbs fitted with new gaskets cuz one was dropping bad so after he did it the one is still dripping. I think it's from the carb bowl. Its the first left one for cylinder one. Is there a reason the gasket might not seal?
Adam james
- Tyrell Corp
Re: carb bowl drip still....
06 Nov 2015 05:47
Sometimes it will fix itself overnight as the gaskets swell up in contact with petrol. Carefully retighten the float bowl fixings if needed.
Some of the pattern float valves and particularly the O rings could be better.
- Kwaker2000
06 Nov 2015 05:51
does not sound like gasket problem, might be the fuel level the carbs sometimes have a small vent hole where the gas can escape , the floats might be sticking or need adjusting
- Online
06 Nov 2015 05:56Kwaker2000 wrote: does not sound like gasket problem, might be the fuel level the carbs sometimes have a small vent hole where the gas can escape , the floats might be sticking or need adjusting
Agree.
Measure fuel level in the carb to see what the real problem is.
- blink543
06 Nov 2015 06:03Tyrell Corp wrote: Sometimes it will fix itself overnight as the gaskets swell up in contact with petrol. Carefully retighten the float bowl fixings if needed.
But the gaskets were replaced like 4 months ago. And it's still dripping
Adam james
- Online
06 Nov 2015 07:06blink543 wrote:Tyrell Corp wrote: Sometimes it will fix itself overnight as the gaskets swell up in contact with petrol. Carefully retighten the float bowl fixings if needed.
That's because the issue is not the bowl gaskets.
- blink543
06 Nov 2015 10:09Kwaker2000 wrote: does not sound like gasket problem, might be the fuel level the carbs sometimes have a small vent hole where the gas can escape , the floats might be sticking or need adjusting
Where's the vent hole on the mikuni vm 22s?
Adam james
- Tyrell Corp
06 Nov 2015 14:06 - 06 Nov 2015 14:08
Now we know it has been leaking from 4 months ago, but I've had this a couple of times myself with new float bowl gaskets.
Last edit: 06 Nov 2015 14:08 by Tyrell Corp.
- blink543
06 Nov 2015 14:25Tyrell Corp wrote: That's because the issue is not the bowl gaskets
So what did u do about it? Just leave it?
Adam james
- Tyrell Corp
06 Nov 2015 17:54
yes, but it was only a couple of tears of leakage around the gasket faces and it sealed up within a day.
Check your float bowl fuel level for starters, cylinder 1 carbs tends to get all the crap when the bike is parked on it's sidestand, so leaky needle valve issues seem more common here..
07 Nov 2015 02:06
What model carbs ?
- 76z1-78kz
07 Nov 2015 04:24
HI. i dont know if this has been mentioned, but i had 2 carbs that would not stop leaking, and it drove me nuts? finally i took the bowls off and held my finger on the end of the overflow tube and blew into the other end to find i had a small crack in the overflow tubes. replaced the bowls and problem solved
