Cv34 38 pilot jet ???
- objec123
18 Oct 2015 13:55
I keep reading about how the 38 pilot jet can't be found. I have been jetting my cv34s for pods and short exhaust, been thinking of trying this 38 jet. Jetsrus.com has them for 12$ ech. Looking for 38 pilot jet reviews on a kz750 four with pods and short exhaust.
- undiablo
Re: Cv34 38 pilot jet ???
19 Oct 2015 05:42 - 19 Oct 2015 05:46
They appeared at Jetsrus.com about 4 months ago. Before that, different than #35 slow pilot jets were called unobtanium.
Nonetheless, there is still no report from any user about #38s.
Price might have something to do.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
Last edit: 19 Oct 2015 05:46 by undiablo.
- undiablo
19 Oct 2015 05:44Attachment 35slowjetvs-2.jpeg not found
- objec123
02 Nov 2015 06:55 - 02 Nov 2015 06:56
i have the 38 jets from jetsrus, the holes are smaller on the 38 than the 35, wtf...
the new 38 jets look right, they do fit but the 3 small holes on the sides of the tube are smaller
Last edit: 02 Nov 2015 06:56 by objec123.
The following user(s) said Thank You: JR, undiablo
- JR
Are there 3 holes on each side for a total of 6 ? or just 3 in total ? also jet should be open at the bottom end I would hope that the hole at the threaded end is larger than on the 35. I'm very interested to hear how your bike runs with these and I'm sure undiablo is also. Thanks for the update
The following user(s) said Thank You: undiablo
- objec123
02 Nov 2015 09:45 - 02 Nov 2015 09:52
3 holes on each side, same as oem 35, just smaller
s28.postimg.org/sqhvqq8bh/jets.jpg
bike idled lean, popping from carbs, sounded very lean. did not ride it. put oem 35s back in.
currenty running 35, 70, 140 with a/f screw 5 turn out. bike runs pretty damn good. pods and short exhaust, cold chicago weather
Last edit: 02 Nov 2015 09:52 by objec123.
- JR
02 Nov 2015 11:06
Thanks again objec123 for checking this out. I had same jet combo as you when I had K&N pods and bike ran fine. I put an airbox on for a more stock look and went down on the primary and secondary mains but always wondered if larger pilots would be good for cold starts and warm up
I guess the 38s from jetsrus are different style
- objec123
02 Nov 2015 11:41
this is from mike at Jetsrus.com "The hole in the center is what the 35 or 38 refers too. So you should not be able to see much of a difference in the diameter of the center hole. The cross drilled holes in the side are the emulsion holes. When keihin originally made these jets they did have different size cross drilled holes-making it even more confusing- so you could have a 38 with big or little cross drilled holes. "
when i tried the 38s i had a/f srew 2 turn out, and it ran crappy, thought if i had it 5 turns out on the 35s then id go 2 turn out with the bigger 38s, dont know what to think now.
- undiablo
03 Nov 2015 03:39
Objec123, thanks for your input.
I think you must enlarge the emulsion holes to the same diameter as in OEM #35 jets. Not an easy task with micro drill bit.
Do you have a vernier caliper to measure the emulsion holes o the #38 jets? I will measure the OEM #35 today.
03 Nov 2015 04:50
Making the holes larger will make them leaner.
- undiablo
03 Nov 2015 07:01
swest,
bigger holes more air in right?
