New versus Rebuilt Carbs
- Vintage3
16 Oct 2015 12:23
Hi,
Just a quick question. Are brand new carbs less temperamental than thoroughly rebuilt and cleaned carbs on start up for a bike that sits a lot? Assume everything else on bike is fine. In response if you could let me know what you consider thorough too for the rebuild for the comparison as this would be helpful. My guess here is the answer would be yes. Rough starts would likely be due to old gas, gummed carbs or dirt from gas in carbs, yes?
Thanks,
Thanks,
Re: New versus Rebuilt Carbs
16 Oct 2015 12:29
You need to tell us what carbs you are dealing with. For example - rebuilding VM24SS carbs is not necessary (unless some one damaged something when fiddling with them) since there's precious little that can wear out; cleaning them is sufficient and in most cases better than installing aftermarket parts of unknown quality. On the other hand, if the carbs are CV type the diaphragms may be damaged in which case they should be replaced. Ed
- jackleberry
16 Oct 2015 13:01Vintage3 wrote: Hi,
Thanks,
Let me just say this: I doubt your starting problems are related to 'gummy' gas.
More likely, one or more of the following is true: you have low compression, your valve stem seals leak, your petcock leaks and your float valves leak. This will result in oil fouled and flooded cylinders which make starting difficult (which is made worse by low compression).
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
16 Oct 2015 15:05
Neglected valve adjustments.
