popping from carbs
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: popping from carbs
12 Oct 2015 15:13
#694318
daveo wrote:
swest wrote: Just replaced my holders. New ones cost less than $100.
To abuse a phrase..."what difference did it make?" :ohmy:
It stopped spitting out of the carbs, the idle was better and the pilot system works better. :woohoo:
  • objec123
  • objec123's Avatar Topic Author
12 Oct 2015 15:25
#694322
bountyhunter wrote:
objec123 wrote: pops with stock jetting and 70 140
If that's pods with stock jetting, I'm surprised you can even ride it. Will run terribly lean.
starts and runs, just feels like that 1 cylinder is down.
was riding it last week for first time with 70 140 and it was great. slowly its been getting worse, now i dont want to ride it, just fix it is all i can think about.
  • objec123
12 Oct 2015 15:30
#694323
i just went through the manual about the valve adjust service, didnt see anything about removing the buckets to get to the shims. i also saw the special tool for shimming. does it let you remove the bucket an shims without removing the cams?
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 Oct 2015 16:17
#694328
You need a manual. You do take out the cams to get to the buckets on a 750 four, not on a twin.
12 Oct 2015 16:21
#694331
objec123 wrote: i just went through the manual about the valve adjust service, didnt see anything about removing the buckets to get to the shims. i also saw the special tool for shimming. does it let you remove the bucket an shims without removing the cams?
What manual said that?? Ed
  • objec123
12 Oct 2015 16:45
#694337
no manual said that, i was just asking about the tool.
i have the manual in pdf, thats all so far.
  • KZB2 650
  • KZB2 650's Avatar
12 Oct 2015 16:51
#694340
The special tool is for 900/1000s you defently need to remove the cams and buckets for shim removal and new carb holders were one of the best investments I made in my opinion..... they may look ok but won't reseal at the head once they are removed and sealer is only temp.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • objec123
12 Oct 2015 16:59
#694343
where is the best deal on new carb holder (intake boots) ?
  • KZB2 650
  • KZB2 650's Avatar
12 Oct 2015 17:04
#694345
I got a set from Z1 and another for the smooth bores over Ebay...... was 2 years ago already now.
1978 KZ650 b-2
  • SWest
  • SWest's Avatar
  • 10 22 2014
