Fuel connectors for the mikuni carbs?
- 650 in Vegas
30 Sep 2015 17:08
I have a '79 650 with Mikuni Carbs and the fuel connector between carb 2 and 3 is leaking gas like crazy. What is the best place to source it and the other two fuel connectors (1-2, 3-4)? I checked Z1 and they only have aluminum ones that they peg as being for a Suzuki.
79 KZ650 C - The best $200 I have ever spent!
Re: Fuel connectors for the mikuni carbs?
30 Sep 2015 17:32
You can try jetsRus. It could be the O rings.
- 650 in Vegas
Re: Re:Fuel connectors for the mikuni carbs?
30 Sep 2015 17:36
I was wondering if I could just replace the o-rings, or it I had to replace the whole thing. I don't have it apart right now, and I don't remember if the o-rings are separate pieces, or if they are part of the connector.
30 Sep 2015 17:44
Some are "rubberized" some aren't.
- 650 in Vegas
30 Sep 2015 18:23
If mine are the rubberized type (I'm pretty sure they are) is there anything that I can do with them, or should I replace them? And if I should replace them, then back to the first question as to where to get the parts (I'm looking at jetsrus but I haven't fount them yet).
30 Sep 2015 18:34
You might be able to clean them up, smear a little grease on them and run them.
- jdvorchak
30 Sep 2015 18:55 - 30 Sep 2015 18:56
Most of the Mikuni and Keihin carbs use O-Rings on the interconnects. You have to take it apart anyway to either swap the tubes or put in new O-Rings. I would do a google search on the model carbs for an exploded parts view. That should answer the question of O-ring or not.
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
John
83 KZ550M1
83 KZ1100LTD
Also own:
Last edit: 30 Sep 2015 18:56 by jdvorchak.
- rhityx02
01 Oct 2015 07:17
I got a these from Z1. Mine were leaking too. Once I took them apart I found the aluminum was cracked.
www.z1enterprises.com/ShopByCategory.asp...egory=01010103020702
Good luck...keep us posed,
Ty
Ty
1977 KZ650 B1
Ty
Ty
- jeff80kz1000e2
01 Oct 2015 10:51
My 80 kz1000e2 had the rubberized ones. I bought aluminum ones off ebay ( I think? ) for a good price. They are functioning great so far after about 3 seasons.
- KZB2 650
02 Oct 2015 06:37650 in Vegas wrote: I was wondering if I could just replace the o-rings, or it I had to replace the whole thing. I don't have it apart right now, and I don't remember if the o-rings are separate pieces, or if they are part of the connector.
Click on the link provided for Z1 and click the tee ....... they sell the o rings seperatly for .79 cents each there .... on my 78 that cured my problem... hoping the 79 is the same. Thinking it took 12...... I've heard of them drying out and a little gas swelling them up and sealing them but mine were pretty loose from sitting while I used the smooth bores.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- pete greek1
02 Oct 2015 09:32I've heard people use these metric Nitrile o rings from Harbor Freight650 in Vegas wrote: If mine are the rubberized type (I'm pretty sure they are) is there anything that I can do with them, or should I replace them? And if I should replace them, then back to the first question as to where to get the parts (I'm looking at jetsrus but I haven't fount them yet).
www.harborfreight.com/225-piece-metric-n...ssortment-67609.html
Pete
- KZB2 650
02 Oct 2015 09:42pete greek1 wrote:I've heard people use these metric Nitrile o rings from Harbor Freight650 in Vegas wrote: If mine are the rubberized type (I'm pretty sure they are) is there anything that I can do with them, or should I replace them? And if I should replace them, then back to the first question as to where to get the parts (I'm looking at jetsrus but I haven't fount them yet).
Pete
That's a thought too (probably a better one) I bought the same set but after I got my other ones from Z1 ...... at least I was placing a order for a few other things so I saved on the shipping.
1978 KZ650 b-2
