Fuel selector filters
- missionkz
30 Sep 2015 11:35 - 30 Sep 2015 11:37
Does anyone know if these little filter tips, slid on to the stock fuel selector's brass tubes, are found anywhere?
They slide off with not too much trouble.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 30 Sep 2015 11:37 by missionkz.
Re: Fuel selector filters
30 Sep 2015 11:56
I think Ed found some a couple weeks ago.
- missionkz
30 Sep 2015 12:08
I have a ball of fuel proof nylon batting safety wired to the brass tubing now and feel like an idiot doing so ... but no junk has gotten past it.
Bruce
1977 KZ1000A1
1977 KZ1000A1
30 Sep 2015 12:12
I think I saved the link but I bought a new lap top for the bike. Maybe under fuel strainers?
30 Sep 2015 12:15
- missionkz
30 Sep 2015 12:22
Thanks..... $3.00 for a pair at 1/10 ounce and $6.62 for shipping with shipping materials for that pair seems rather expensive Yes? No?
Still I have none.... except the cracked one in that picture.....
Bruce
1977 KZ1000A1
1977 KZ1000A1
- missionkz
30 Sep 2015 12:27 - 30 Sep 2015 12:30
My brass tube measures right in at under 6mm in diameter.... the website says the inside diameter of the filter is 6.7mm...
I wonder if that is too big and would pop off?
added:
The inside dim of my removed filter is 5.96mm I'm betting that extra .75 means the replacement one it doesn't stay on the brass tube....
Has anyone tried these yet?
added:
Bruce
1977 KZ1000A1
1977 KZ1000A1
Last edit: 30 Sep 2015 12:30 by missionkz.
30 Sep 2015 12:30 - 30 Sep 2015 12:34
I'm going to buy some. I can just use my heat gun if needed. The one on the main tube was broken when I got the petcock from z1partsinc. Had some SHT get into my petcock and scored the inside. I had to sand everything to get it to shut off the fuel fully.
Last edit: 30 Sep 2015 12:34 by SWest.
- pete greek1
30 Sep 2015 12:42I wonder if you could use a tight fitting Viton O-Ring to slip over & down to the bottom to hold it on & close the gap ?missionkz wrote: My brass tube measures right in at under 6mm in diameter.... the website says the inside diameter of the filter is 6.7mm...
added:
Pete
- moneypit
01 Oct 2015 10:53
Missionkz the inside diameter is 5mm
Petcock fuel pipe Filter Set(2)
Fits: Over petcock fuel pipes up inside gas tank.
Filter Set - Replacements for #20-0019 petcocks and will also fit 1970-77 XS1 XS2 XS650 stock petcocks.
Dimensions: 5mm Inside - 6.7mm Outside - 31.75mm Length.
2-76 kz900
St Paul MN
St Paul MN
