1980 KZ750E1 carb kit help
- DivideOverflow
20 Sep 2015 08:35 - 20 Sep 2015 08:35
Hello, I've purchased carb rebuild kits for my KZ750E1 from z1 enterprises. I have a question:
What the heck are the parts supposed to replace. The needle doesn't look remotely like the one in my bike, and I'm unsure where the orings and little washers are supposed to go. The little spring and spacer are a mystery to me too.
I do have a Canadian spec KZ, but I didn't see anything that would indicate the carb is different.
Any help would be much appreciated.
1980 KZ750E1
North Carolina Crew
North Carolina Crew
Last edit: 20 Sep 2015 08:35 by DivideOverflow.
- gd4now
- Denco where did you go?
Re: 1980 KZ750E1 carb kit help
20 Sep 2015 08:57 - 20 Sep 2015 08:58
What kit did you purchase? From the pics you posted I do not see any needle in the kit, rather a pilot screw which does come to a very sharp point. The small spring is for this pilot screw as is a washer and o-ring.
The link below should take you to the Kawasaki web site carb diagram fro the 80 KZ750 E1
www.kawasaki.com/Parts/PartsDiagram/134831/1980/KZ750-E1
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Last edit: 20 Sep 2015 08:58 by gd4now.
- DivideOverflow
20 Sep 2015 09:14
Ah!! Thanks. I didn't even know the pilot screw was there. I admit to not being super familiar with this carb.
Thanks for the link.
1980 KZ750E1
North Carolina Crew
North Carolina Crew
20 Sep 2015 09:53
Why did you buy carb kits? Ed
- JR
20 Sep 2015 11:28
One o ring one washer and spring for the pilot/mixture screw
One o ring for the bowl drain plug
One o ring (which you might need to file down with an emory board) for the plug over the pilot jet
- DivideOverflow
20 Sep 2015 11:55
I got rebuild kits because I had a terrible time getting the carbs synched, and it was running rough, and not warming up well at all.
I had assumed the kits would come with everything I needed parts wise.
So far, two plungers on the float needles were completely shot, one pilot mixture screw had a broken tip and no washer or o-ring, and one of the pilot mixture screws is totally stripped and I'm going to have to try and drill it.
Also, I realized how stupid my question was after I said it... I haven't looked at the bike in months after my synch attempt (with a manometer) failed. I just had a "duh moment" and didn't know what the pilot mixture screws looked like because I didn't pull them out.
Anyone have luck drilling out the pilot mixture screw before? I provided a picture of how screwed I am. Lol.
1980 KZ750E1
North Carolina Crew
North Carolina Crew
- JR
20 Sep 2015 13:49 - 20 Sep 2015 15:02
In your 3rd pic I MG 16 43, carb on the left , It looks like it's just the cap over the mixture screw that's a bit buggered. You have one in the carb kit so you can gauge the thickness. If you drill slowly and carefully until the bit just goes through it you should be able to prise it out without damage to the screw beneath.
Last edit: 20 Sep 2015 15:02 by JR.
- DivideOverflow
20 Sep 2015 15:23JR wrote: In your 3rd pic I MG 16 43, carb on the left , It looks like it's just the cap over the mixture screw that's a bit buggered. You have one in the carb kit so you can gauge the thickness. If you drill slowly and carefully until the bit just goes through it you should be able to prise it out without damage to the screw beneath.
It is funny, it is so chewed up, it actually looks like a screw head when you look at it in person... But the photo obviously looks like aluminum and not brass. I do hope it is just the cap!
1980 KZ750E1
North Carolina Crew
North Carolina Crew
- DivideOverflow
23 Sep 2015 13:22
Well, it was the screw! Not the cap. But I got it!!
1980 KZ750E1
North Carolina Crew
North Carolina Crew
- JR
23 Sep 2015 13:51
Ugh
That was nasty :sick:
Well done
Well done
- gd4now
23 Sep 2015 18:30
Agree well done!
1977 KZ650 B1
- DivideOverflow
06 Dec 2015 13:11
Ugh, very frustrated.
I finally had time to finish up, got the carbs back on the bike with new carb holders + airbox boots, and I'm having the same issues I was before. I get the bike started, but it will only start with throttle (choke at any setting doesn't help), then once it warms up a little it will idle, but the rpms just continue to go up as the bike warms up, and when you give it any gas, the rpms go up but really don't want to come back down.
The left side of the exhaust (while on the bike) was also spewing exhaust smoke (unburnt fuel maybe?), which is new, but it also backfired on that side.
I'll have to wait to try and do the wd-40 test to see if there are any leaks. After putting on new holders and boots (as well as going through the carbs), I'm pretty pissed and fed up with this bike.
1980 KZ750E1
North Carolina Crew
North Carolina Crew
