Paper or K&N filter ?
  • spdygon
  • spdygon's Avatar Topic Author
16 Sep 2015 16:38
#690389
So I installed a 75 z1 air box on my 76 kz900.
Stock motor , 29mm smoothbores and 4 into 1 exhaust.
I prefer the k&n but at $55 ship is a lot when the paper is $12 ship.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
Re: Paper or K&N filter ?
16 Sep 2015 17:28
#690399
The K&N filter does not filter particles as fine as does the stock filter. Ed
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 Sep 2015 17:56
#690403
I've been running K&N's for 30 years. No issues.
  • martin_csr
  • martin_csr's Avatar
16 Sep 2015 23:42 - 16 Sep 2015 23:42
#690417
Do an internet search for K&N air filter comparison test.
I've never seen anything that showed K&N was better than oem at doing the job it's supposed to do --- filter the air.
IMHO, K&N is really just a marketing company. Fram is another one.
Last edit: 16 Sep 2015 23:42 by martin_csr.
17 Sep 2015 01:49
#690420
Here's an independent air filter comparison:
www.nicoclub.com/archives/kn-vs-oem-filter.html
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
17 Sep 2015 05:01 - 17 Sep 2015 05:02
#690453
650ed wrote: The K&N filter does not filter particles as fine as does the stock filter. Ed
In my case, would the Emgo paper air filter be considered a stock filter, or are you specifically suggesting a Genuine Kawasaki 11013-1037 filter?
1982 KZ1100-A2
Last edit: 17 Sep 2015 05:02 by daveo.
17 Sep 2015 05:23
#690455
I don't know how good or bad the Emgo filters are; I have always used Kawasaki air filters. Considering that an air filter lasts a very long time before needing to be replaced I don't consider the price to be a problem. Ed
  • Shabba
  • Shabba's Avatar
17 Sep 2015 07:47
#690486
I've run K&N for 20 years in bikes and cars and have never had issues. My main reason is that they are reusable. Forget the "power gain". It's negligible if at all. I just like cleaning and oiling them as opposed to buying a new one (or a set) every year or so.
-Colin
-82 GPZ750
-15 Yamaha FZ-09
-00 Suzuki TL1000S
-13 Nissan Nismo Juke
  • loudhvx
  • loudhvx's Avatar
17 Sep 2015 09:23 - 17 Sep 2015 10:13
#690506
Plus all the labor and chemicals... yuck. Once the K&N is fully oiled and sticky, it doesn't really flow any more air, so what's the point of doing all the extra work and laying out all the extra cash?
Daveo:
I've used Emgo replacements for stock filters for many years. It didn't seem to be any different from the factory filter in regards to filtering or flowing, but I didn't do any serious testing... just looked at the dirt accumulation and felt how it ran, which were the same, as far I could tell.
Last edit: 17 Sep 2015 10:13 by loudhvx.
  • spdygon
17 Sep 2015 12:54
#690540
Well for $12 bucks....can't go wrong.
It's not like I'll drive 20k miles a year.
1974 Z1 900 project
  • SmokyOwl
  • SmokyOwl's Avatar
17 Sep 2015 13:31
#690548
OK somebody needs to stand up here and say why K&Ns oiled filters are not worse than OEM filters. I'll give it a shot.
"They allow larger particles of dust into the engine".....These particles are so small that if by some miracle the particles got past the OIL-SOAKED air filter, the explosion of the engine's combustion chamber would turn it into a nuisance similar of a mosquito being sucked into a jumbo jet's engine. And by this logic, by not soaking up as many particles this allows the filter to last even longer. The only people who should be concerned with this is if you must drive through a sandstorm to get to work daily....and who doesn't want to do that?
"It's expensive"....I don't know about you, but I'd rather ride than work on a bike. These filters last longer than oem before you have to do anything with them, and then it costs you $10 to $20 for a recharge kit that pretty much will last you longer than any vehicle's life. So $15 every 1 or 2 years....or $75 for forever? Kinda evens itself out pretty easily. These oil filters last longer because they allow more air to pass through with less vacuum, and therefore it takes more time for them to get dirty enough to need servicing.
I agree on that hi-flow filters alone do not give you more horsepower. They give you more horsepower only when then engine has been modified to the point that it needs more air from the intake than the stock setup can provide.
1982 Kawasaki KZ1100 A2, Shaft
Never trade the thrill of living for the safety of existance.
17 Sep 2015 14:05
#690559
SmokyOwl wrote: ........ These oil filters last longer because they allow more air to pass through with less vacuum, and therefore it takes more time for them to get dirty enough to need servicing.
Actually, that is not what the study found. It found "The AC Delco filter test ran for 60 minutes before exceeding the restriction limit while the AMSOIL and K&N tests each ran for 20 and 24 minutes respectively before reaching max restriction."
Attachment 00003a-106.jpg not found
