Pods, Tk carbs, struggles
- Jonny6guns
Re: Pods, Tk carbs, struggles
04 Sep 2015 06:45
I have not done anything with valves. Don't think I have the tools for it. Would a valve issue come up out of the blue after running good for the last year?
04 Sep 2015 07:04
Yes, they will get tighter with time. The one plug suggests a intake valve is too tight. I'd be willing to bet you have tight valves. Burn one, the head has to come off, now you're into REAL money. :ohmy:
Do yourself a favor and check them. Cheap insurance. :whistle:
- Jonny6guns
04 Sep 2015 08:16
Do you check them by pulling the valve cover and measuring the clearance between the valve cap and the cam?
- loudhvx
04 Sep 2015 09:12
If your compression test shows good, I would start looking into the ignition next. Since it is 2 and 3 that are looking bad, I wonder if you can swap the coils to see if the problem moves to 1 and 4. OR it could be you have massive vac leaks on 1 and 4. Are you even sure it's running on all four cyclinders? You can spray water on the headers to determine if one or two cylinders are not firing. The water should dance off the cylinders that are firing.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Jonny6guns
04 Sep 2015 09:21
I also wanted to mention that when the bike was idling last night it would idle ruff then rev up and not want to come down ever when off choke.
