Installed 120 jets n 17.5 pilot
- Turbo99397
30 Aug 2015 17:54
I went up from 102.5 main to 120 and 15 pilot to 17.5. Low end to mid range is sort of lacking and high end could be stronger.. I have pods and a kerker 4 to 1 I bought it like that, wish I had stock airbox but don't. Few questions ..
Would adjusting the clips for needle height help any?
I want to try one more jet combo.. I'm thinking 130 main and 22.5 pilot.. or do u think 125 would be better... if I gas it I first the front end won't come up. Not in any gear just feels alot better with the new jets but still needs more. Any input greatly appreciated, thx
Re: Installed 120 jets n 17.5 pilot
30 Aug 2015 18:43
Pics of plugs.
- Turbo99397
05 Sep 2015 07:50
Center r wet and outer have a little white. But I had to limp it home abt 10 miles after center 2 quit.
05 Sep 2015 07:58
When was the last time the valves were adjusted?
- Turbo99397
05 Sep 2015 08:05
Idk Iv never done it. I bought the bike July 4th, don't have new valve cover gasket so I haven't done any checking on the valves yet. Wasn't sure old gaskets would seal properly
- gd4now
- Denco where did you go?
05 Sep 2015 09:04
Sorry but I do not see what bike and what carbs your a working with. Different answers for different size bikes and carbs.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- Turbo99397
05 Sep 2015 09:45
80 kz1000. Mechanical mikuni carbs with smooth bore slides. Stock electronic ignition
- Kapahulu
07 Sep 2015 16:43
Try 20 pilots. For a stock bike the 120 mains are probably right or very close. Checking valve clearance is a great idea.
2strokeworld.com
2strokeworld.com
