leaky boots all around
Re: leaky boots all around
30 Aug 2015 11:23
Hand impact driver to remove these screws if they've been in there for long. Get the 3/8" so you can use it for sockets and Allen sockets. A must for any tool box.
- 82KZ305Belt
30 Aug 2015 11:26
Is 33 years "long"? :lol:
81 KZ650 CSR
77 KZ650B (not in my paws yet)
82 KZ305 CSR
82 KZ305 CSR
30 Aug 2015 11:29
I'd say. :whistle:
- 82KZ305Belt
05 Sep 2015 07:39
I'm happy to report that a few days of Liquid Wrench and the above mentioned snub-nosed bit in a 1/4 inch drive ratchet pulled those puppies out easy as butter. The one boot took minor effort to dislodge while the other one just fell off when I took the screws out. Oh yeah-it was time for new ones!
81 KZ650 CSR
82 KZ305 CSR
82 KZ305 CSR
05 Sep 2015 13:42
Excellent! It takes a bit of patience to let the screws soak, but it is well worth the wait! Ed
- KZB2 650
05 Sep 2015 14:14 - 05 Sep 2015 14:17missionkz wrote: If you are not a purist, replace all those awful JIS screws with Allen head screws and use stainless steel ones at that.
One of the first things I did on my 650 and way back in 73 on my dare I say it Honda 750. :laugh: You can use your inch Lb torque wrench too this way if you want to really get fancy.
I found out the Master Mechanic #3 and #2 bits fit like they were modified too....... perfect fit on the JIS screws...... and my Sears impact has saved me a few times.
Ed what do you think about blue lock tightin them in too ..... if I read it right my factory manual recommends this and I always have ..... Also Yoshi's #1 mechanic (at the time) recommended this to me in a hand written letter many years ago when I asked them about what manifolds I needed and jetting for the 29mm smoothbores to fit. (Not being a smart azz.... I know we got in a pretty ggod argument over something close to this years ago and I'm not .)
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 05 Sep 2015 14:17 by KZB2 650.
- 82KZ305Belt
06 Sep 2015 10:50 - 06 Sep 2015 10:50
yep, that's the secret to any penetrating oil. Even PB Blaster works if it sits long enough. I thought penetrating oils were pretty useless until I figured out they work best over days not minutes or hours.
650ed wrote: Excellent! It takes a bit of patience to let the screws soak, but it is well worth the wait! Ed
81 KZ650 CSR
82 KZ305 CSR
82 KZ305 CSR
Last edit: 06 Sep 2015 10:50 by 82KZ305Belt.
Yes. The Kawasaki Service Manual calls for a non-permanent locking agent on the carb holders screws. Blue loctite is perfect for the job. That's exactly what I used when I replaced mine. Ed
