- Thank you received: 36
leaky boots all around
- 82KZ305Belt
The manifold boots look like new and are still pliable, but are leaky. I suppose I can try new clamps and see if that does anything but what if it doesnt? No way I'm going to waste good money on 35 year old used boots off fleabay or a junkyard. What do I do if I need to replace boots all around? And do the airbox boots really matter right now? I always thought it was leaky manifold boots that cause racing
- Thank you received: 2756
- 82KZ305Belt
- 82KZ305Belt
- Thank you received: 2829
82KZ305Belt wrote: Why would they be leaking if they look great?
Looking great has nothing to do with them leaking. My original carb holders looked like new, but I discovered they were leaking badly which caused very erratic idle. They didn't leak at all along the tube sections. Over time from heat and age they developed hairline cracks on the surfaces that mate against the cylinder head. These cracks cannot be seen with the carb holders bolted to the head. When I removed the carb holders (they failed the leak test) I could see very fine cracks on those mating surfaces when examining them through a magnifying glass. I replaced them with new ones and the problem was completely solved. Ed
- 82KZ305Belt
swest wrote: The Permatex sealed them but only for a while.
82KZ305Belt wrote: Bummer...I don't think I'll find any new ones so redneck repair is probably my best solution
STOP! Before you redneck the repair check with a local and/or online Kawasaki parts dealers. All the online sources I checked show the KZ305-B1 carb holders (part number 16065-1013) as still being available. Ed
Attachment 00003a-96.jpg not found
- 82KZ305Belt
650ed wrote: Before you redneck the repair check with a local and/or online Kawasaki parts dealers. All the online sources I checked show the KZ305-B1 carb holders (part number 16065-1013) as still being available. Ed
