Synchronization on my '81 KZ550 ltd
- Couturier
25 Aug 2015 07:09
Hello,
I have recently started my kz550 after close to a year not running it due to me modifying it. I finally plugged the gauges to synchronize the carbs. On cylinder 1-3-4, I have a similar reading of about 12-13 inches of mercury, but on cylinder 2 I only get about 9 inches. The thing is in the manual, they recommend having a vacuum between 19 and 24 CM of Hg witch translate to 7,5 to 9,5 INCHES of Hg. Should I then dial down the vacuum on cylinder 1-3-4 to within the range or try and move up cylinder 2 to match the other 3?
The modifications on the bike are a new 4 into 1 custom air filter i made out of a K&N filter and a 4-1 exhaust with and somewhat straight pipe muffler. I rejetted the carbs to #100 main and #37 pilot and also moved the clip from #2 to #4. The Bike runs well on idle but revs slowly in my opinion. Also It seems like i have some valves clearances to address, specially on cylinder 4.
Thank for the help!
Thank for the help!
1981 KZ550 Ltd.
- Couturier
Re: Synchronization on my '81 KZ550 ltd
25 Aug 2015 07:12
Here's a link for the filter if you are interested... (dunno if it'll work)
Attachment ScreenShot2015-08-25at9.55.11AM.png not found
1981 KZ550 Ltd.
25 Aug 2015 07:56
Adjust your valves first. Check timing and other components, then try to dial in the carbs. If one carb doesn't have a adjusting screw, make all the others match it. If you try to set the others to the same as #2, your idle will drop. I suggest setting it to match the other three. The valve adjustment might change all that. Do that first.
- loudhvx
25 Aug 2015 08:09
Adjust the one that is different. When you adjust the idle speed accordingly, that will cause the others to change as well. They all affect each other, and the idle knob affects all of them.
But the fact that #2 is so different can mean a vacuum leak or other engine condition like Swest mentioned. You may want to start at the beginning and do a full base line tune. That starts with the compression test and valve clearance check.
If you do that, make sure to read the valve train warning in my signature.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Couturier
25 Aug 2015 08:20
Ok I will check the valve and the compression first, and get back to you guys.
Thank you
Thank you
1981 KZ550 Ltd.
- Tyrell Corp
25 Aug 2015 10:54
low vac on one can be an inlet valve problem if checking clearances and intake leaks doesn't fix it.
- apbling
25 Aug 2015 13:24
How did you make that intake? kinda cool! Also, got a pic of that exhaust?
- Couturier
25 Aug 2015 14:56
It's carbon fiber fabric molded against regular house hold styrofoam. It's the first version...
As for the muffler here's a link :
www.dimecitycycles.com/vintage-cafe-race...muffler-80-2250.html
1981 KZ550 Ltd.
- Couturier
26 Aug 2015 17:22
So I've tried doing the valve clearance check but I could only find the 1 4 T mark on the timing element, no 2 3T mark.... So I did the best I could but still im not sure of the measurements I took for the clearance. Any thoughts?
1981 KZ550 Ltd.
26 Aug 2015 17:26
Pics? Check them with the cam pointing away from the lifter.
