bike not idling
  • ar20024u
  • ar20024u's Avatar Topic Author
bike not idling
20 Aug 2015 14:31
#686512
I got a 84 gpz550 with a stage 3 jet kit and unifilter pod filters, and a kerker megaphone. bike was running fine but leaking fuel from the horizontal connection pipe. orings bad. I took the 4 carbs off and replaced the orings.
now all put together, the bike does not want to idle. it will run only on full choke. I have the 4 vacuum pipes open. is that a cause? do I need to connect the 2 vacuum pipe to the evap control system and 2 to the fuel tap? I was going to use a homemade sync tool to sync the carb since I took them apart.
any ideas suggested what I need to do for it to run fine. the air screws are out 3.5 turns.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: bike not idling
20 Aug 2015 14:36
#686514
Plug them. One should go to the petcock.
  • Irish Yobbo
  • Irish Yobbo's Avatar
Re: bike not idling
20 Aug 2015 17:01
#686538
As a disclaimer I don't know these carbs - but the vacuum pipes on every carb I know shouldn't be left open. They will let air into the carb - under load the amount of air usually isn't enough to seriously change things, but at idle it is very noticeable.
Anything that attaches to the vac pipes should provide resistance - if it's connected to a vac advance unit, it's really just providing negative pressure, not allowing any air in. In my car I use a vac line to feed flash-lube into the fuel, since it's such a small amount and feed very slowly, it's effectively no different to having the port plugged.
1981 KZ750 LTD
Re: bike not idling
20 Aug 2015 17:47
#686545
See following links courtesy of KZr Member loudhvx :cheer:
General
home.comcast.net/~loudgpz/GPZweb/index.html#home
Service manuals
home.comcast.net/~loudgpz/GPZweb/Mnls/Mnls.html
Good Fortune! :)
Re: bike not idling
20 Aug 2015 17:54
#686547
The "Clean Air" paraphernalia isn't necessary and is easily removed. :cheer:
When left installed, the system adds to sources of possible air leaks. :pinch:
Good Fortune! :)
  • aarb77
  • aarb77's Avatar
Re: Re:bike not idling
29 Aug 2015 15:21
#687666
Patton does this also work the same with the 82 KZ550 LTD with TK Carbs? Should these be plugged? I am getting alot of black smoke. I have a thread open and could use some help, running rich.
RB
