VM29 jetting for 738cc performance Bike
- Dirtyhands
08 Aug 2015 21:38 - 09 Aug 2015 00:16
Hey all, Let me start out by thanking everyone that helped me out with my Cam degreeing. The bike bike is mostly great now but needs the carb jetting ironed out to be perfect. In addition to valves and degreeing the cams I've essentially switched out the entire electrical system and while the bike seems to improve on every step I take it still has some bugs.
This is the set up
Kz650 with Big Bore 738cc kit
.410" lift cams with 250degree duration
Dyna S cdi with Dyna 3ohm coils
Electrosport stator and regulator/rectifier installed with new motobatt battery
4into1 pipe
2 2into1 pod fiters
The carbs are VM29 smoothbore carbs
The current jetting in the VM29s is what I assume to be to rich with a 135 main jet 20pilot jet 2.5 valve seat 1.5 slide and 5dl31 needle
I'm getting pretty awful gas mileage and having some inconsistency in my idle and at times mid throttle (around 6000 rpm) Let me know what you guys think, and here's a picture of er.
This is the set up
4into1 pipe
2 2into1 pod fiters
Attachment 11200874_10152986681870488_8779531715944587541_n.jpg not found
1977 KZ650B
KZ750H Motor Installed
gpz750 Intake cams Kz750 Exhaust Cams
VM28SS Mikuni Pumper Carbs
Elecrosport Stator and Regulator Rectifier
Dyna 3ohm coils
Derale Oil Cooler
4into1 delkevic Pipes
Pod Airfilters
Dyna 3ohm coils
Derale Oil Cooler
Pod Airfilters
Last edit: 09 Aug 2015 00:16 by Dirtyhands. Reason: mistake
The following user(s) said Thank You: KZB2 650
- Dirtyhands
Re: VM29 jetting for 738cc performance Bike
08 Aug 2015 22:31
Just realized I posted this in the engine category when it should be in Carbs sorry guys. Is there a way to switch it over?
1977 KZ650B
Dyna 3ohm coils
Derale Oil Cooler
Pod Airfilters
Dyna 3ohm coils
Derale Oil Cooler
Pod Airfilters
- zukdave
09 Aug 2015 06:16
Sudco lists 25 pilot and 125 main as a starting point. for a 750cc motor.
The VM29's get a weak idle signal on the smaller motors and need a big pilot jet to pull fuel.
Right now I've got 22.5 and 122.5 in mine and it's on the lean side
and will be upping both just need to order some 25 and 27.5 polits and some
125, 127.5 and 130 mains to finish tuning them.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
The following user(s) said Thank You: KZB2 650, Dirtyhands
09 Aug 2015 06:37 - 09 Aug 2015 06:38
Done been moved.
Nice bike.
Last edit: 09 Aug 2015 06:38 by SWest.
The following user(s) said Thank You: Dirtyhands
- Dirtyhands
09 Aug 2015 08:33
Thanks Steve! and thank you Zukdave, that seems like a good place to start.are those jetting sizes with the Needle set in the middle?
1977 KZ650B
Dyna 3ohm coils
Derale Oil Cooler
Pod Airfilters
Dyna 3ohm coils
Derale Oil Cooler
Pod Airfilters
- zukdave
09 Aug 2015 11:00
Needle clip one up from bottom or number three slot.
Aslo theres an air jet thats down in one of the little holes as you look in from the filter side.
The smoothies can be a bitch to tune the idle/off idle as they were designed as an after market
race carb so idling was not high on the design list.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
09 Aug 2015 11:11
To be honest if my little bike wasn't track only I'd put a set
of VM28 pumper carb's on it.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- KZB2 650
09 Aug 2015 14:47 - 09 Aug 2015 14:50
Awesome Zuk ....... I have alot more work to get too before I tackle the 29s ...... but probably in the spring..... appreciate the info .... had em on my stock 650 for years with 17.5s and 117.5s and always had that little stubble off idle I could never get rid of !! Went back with the stock 24s a while back since the 900 manifolds finally cracked up too bad to use.
You ment too the 4th slot on the nettle right as you said one up from the bottom ? Will go with at least 20 pilots and 120s to 122.5s.....
How about the air screw ...... turns out ??........... I run in way cooler air than you....... 65 to 85 degrees (mostly 70-75) and am at approx 200 foot above sea level too.............
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 09 Aug 2015 14:50 by KZB2 650.
