TK22 Needle Jet Retainer Screws
- The_Proletariat
- "Cocaine is a hell of a drug"
01 Aug 2015 20:48
To avoid stripping out these screws do not use a phillips screwdriver.
A 1/8 slotted screwdriver works fantastic here.
1982 Kawasaki KZ550 LTD
Re: TK22 Needle Jet Retainer Screws
01 Aug 2015 21:41
Should never use a Philips on any screw on a Japanese bike. The screws are JIS and can easily be wrecked by a Philips screwdriver .
- The_Proletariat
01 Aug 2015 22:12TexasKZ wrote: Should never use a Philips on any screw on a Japanese bike. The screws are JIS and can easily be wrecked by a Philips screwdriver .
Correct, however JIS screwdrivers often cannot be sourced locally. I have only seen JIS bits, and there's no way a bit holder handle will fit into TK22 throttle slides.
02 Aug 2015 05:29
I've used my long Phillips screw driver on carb screws for years. It's the case bolts that it won't fit.
02 Aug 2015 06:15 - 02 Aug 2015 06:16
They are readily available online. For the larger sizes, a Phlllips can usually be modified to work,
www.kzrider.com/forum/21-tools/598060-jis-screwdrivers#672883
Last edit: 02 Aug 2015 06:16 by TexasKZ.
