Tear in carb diaphram!? Bike dying
- Drafter89
01 Aug 2015 16:03
Bike keeps dying when I let of the throttle. Had the carbs off and found a couple open slits on the diaphrams. I posted a pic of one of them. The other diaphram has a couple of teeny tiny rips in it. Will this cause the bike to die like that ? Everything else is in check. Anything I can put on there to seal the openings or do I need to buy new ones?
78 KZ 400 C1-Daily Driver
New Albany,IN
New Albany,IN
- Tyrell Corp
Re: Tear in carb diaphram!? Bike dying
01 Aug 2015 17:29
Your throttle response will be a lot out with split diapragms, also you risk holing a piston(s) due to weak mixture.
I just paid £35 for one diapragm, i did a temporary repair with super glue but it won't last.
This guy is really good, he knows motorcycle carbs back to front. Also a mine of advice on tuning and settings
www.nrp-carbs.co.uk/shop/
01 Aug 2015 17:41
Get new ones. I know they aren't cheap but look how long those lasted. Never run right without them. ALL of them.
- Tyrell Corp
01 Aug 2015 17:59
Hold them up to light, splits start as tiny pinhole almost invisible. I almost missed the split on mine.
I'd advise checking these very carefully given the age of these bikes. Not being a drama queen here, but a split diapragm and a long fast run could be a piston wrecker.
- Drafter89
01 Aug 2015 18:11
Tjats what i did lol. One of the slits is about 1/8 of an inch long lol. And there's a couple of other little holes I can see right through. I'll be replacing as soon as possible. But would these tears cause the bike to die when I let of the throttle like it has been?
New Albany,IN
New Albany,IN
- Tyrell Corp
01 Aug 2015 18:41 - 01 Aug 2015 18:42
Your idle mixture is leaned out -actually everything from shut off to wide open throttle. What was set up right with intact diapragms is now all wrong with the splits.
Two reasons: the manifold vacuum won't lift the slide and needle like it should, also you are bleeding air in...almost like adding another pilot circuit. This is where a muppet would try to tune it out rather than getting to the root problem.
It is an easy fix, but they are quite expensive.
Last edit: 01 Aug 2015 18:42 by Tyrell Corp.
- JR
01 Aug 2015 18:48 - 01 Aug 2015 18:50
check out
jbmindustries.com/
I have never used them but have heard good things and bookmarked their page for when I might need a set for my bike.
Prices look quite reasonable
Last edit: 01 Aug 2015 18:50 by JR.
- Drafter89
01 Aug 2015 19:30
Awesome guys thanks! Will be ordering new ones Monday
New Albany,IN
New Albany,IN
