carbs / petcock
  • originalhandy
  • originalhandy's Avatar Topic Author
carbs / petcock
19 Jul 2015 13:48
#681657
With the tank off the bike and turned to on nothing drains out, when I switch prime it free drains. When I put it on the bike on on position petrol just drains out. I presume petcock needs to be rebuilt? Do the carbs need a rebuild too?
I'm going through a list of things I need to work on.
It's a 80 kz750h
  • Nessism
  • Nessism's Avatar
Re: carbs / petcock
19 Jul 2015 14:12 - 19 Jul 2015 14:13
#681660
originalhandy wrote: With the tank off the bike and turned to on nothing drains out, when I switch prime it free drains.
This is correct. With the petcock set to ON, try putting a piece of vacuum hose on the petcock vacuum port and drawing a vacuum. Fuel should flow and stop as soon as the vacuum is released
originalhandy wrote: When I put it on the bike on on position petrol just drains out. I presume petcock needs to be rebuilt? Do the carbs need a rebuild too?
Where is the fuel draining out? Of the carbs? If so, your float needles are not working so it's carb rebuild time.
Last edit: 19 Jul 2015 14:13 by Nessism.
  • SWest
  • SWest's Avatar
  • 10 22 2014
