Can't sync utter failure
- apbling
Re: Re:Can't sync utter failure
17 Jul 2015 14:01
Wow. Good vac lines make syncing take 5 min. Dialed them all nuts on. Idles smooth as silk now. Couldn't go for spin yet.
17 Jul 2015 15:32apbling wrote: I guess I misspoke. I did bench them by holding a light on the backside and eyeballing it. I also did check the wot position as well.
And Steve, the arms are not bent on the float and the float is not taking fuel on. If it was, it'd sink, not shutting the fuel off. My issue was the fuel level was too low when I measure it with the clear tube method. I'm not sure if maybe my needle is screwed up or the seat isn't the correct one...
That's good. The needles are working like they should. Easy to bend the tang enough to let in more fuel.
- apbling
19 Jul 2015 18:26
Yes they are working but something isn't right. The one carb is adjusted to the max - if I did that on the other carbs they'd be overflowing. So something still isn't right.
- JR
19 Jul 2015 18:30 - 19 Jul 2015 19:15
Float upside down?
done it myself
done it myself
Last edit: 19 Jul 2015 19:15 by JR.
19 Jul 2015 19:10 - 19 Jul 2015 19:11
Last edit: 19 Jul 2015 19:11 by SWest.
- apbling
19 Jul 2015 20:07
Nope. Nearly impossible w the tk22 floats
- apbling
09 Aug 2015 15:21
Ok, carbs balanced, no vac leaks. Took her for a good run yesterday. Has the balls to pull a little wheelie rolling on the throttle hard in 1st. Pulls like a banshee up to 90. But...when I'm at 1/3 throttle and I slam it full open, she coughs then takes off hard. Doesn't do it from closed to full. Makes me think the needles are too low, but I'm running everything stock... Also had an elevated idle when warm and a lot of pipe crackling at de-accel. I know the carbs are clean, I don't have any leaks and they're jetted stock. When I got home I Richened up the pilot screws some, adjusted the idle and put her away for the night... Hope that's my issue because I'm really sick of taking the carbs off
- apbling
14 Aug 2015 15:16
Anyone got any thoughts? Guess everyone is out riding
14 Aug 2015 15:27
A pic showing the carbs and the bike might help.
