Jet questions and a few answers
- Rustyhama
Re: Re:Jet questions and a few answers
12 Jul 2015 00:34
Fair point. I just figured that was a generic diagram.
Hama
'82 KZ305-B1 Cafe Racer
'80 Z750E project
www.dotheton.com/forum/index.php?topic=59260.0
'80 Z750E project
- gd4now
- Denco where did you go?
12 Jul 2015 00:54
The pilot circuit does provide fuel/air mix through out the entire throttle movement. It just has the greatest effect at idle or just off idle before the other circuits in the carb take over.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
12 Jul 2015 07:26
Correct.
- loudhvx
12 Jul 2015 09:13
Yes, everything affects everything, but when it comes to making any measurable effect, it does not. You can test it by changing the pilot and measuring the mixture at WOT. You will not see any difference in mixture at WOT.
I think people don't realize how little throttle they use when cruising on the highway. I think the 550 can sustain 60 mph at just over 1/16 throttle. In that range, the pilot still has some effect. By 1/4 throttle, at least on the TK22 carbs, you will not see any difference in the AFR with different pilots.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- TheForumTroll
Re: Jet questions and a few answers
13 Jul 2015 04:39
Yeah when looking at it like that it does have an affect through the whole range, though not anything measurable or adjustable in the big picture.
-[ KZ700-A1 '84 ]-
- gd4now
21 Jul 2015 22:38
Lou no argument here. At WOT the pilot circuit has no real measurable effect on the air to fuel ratio. It was not intended to do so. As I see it, its real effect is at idle and just off of it. The only thing I was attempting to say was that it continues to provide what it provides throughout the entire throttle movement, it does not stop flowing whatever the mix is. It just keeps adding it.
1977 KZ650 B1
- loudhvx
22 Jul 2015 06:06 - 22 Jul 2015 06:12
I agree with what you're saying. I guess the point is, the chart is meant to convey the range of throttle position a particular adjustment will make a difference on. (And not really what range of throttle position a particular circuit is active.)
But, I see now, you are correct, based on the title of his chart. Note the title is different on mine.
Who knew the title, and labels, of a chart actually matter ? :laugh:
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 22 Jul 2015 06:12 by loudhvx.
- undiablo
13 Aug 2015 09:38
Rustyhama:
Any news of the #38 pilots?
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- Rustyhama
13 Aug 2015 12:16
No... I didn’t buy new pilots, so haven't anything to report, if that's what you're asking.
Hama
'80 Z750E project
'80 Z750E project
- undiablo
13 Aug 2015 13:21
Ok thanks. You are keeping stock #35 then.
