Missing check valve parts in carb bowl
- Lazyman06
25 Jun 2015 07:49 - 25 Jun 2015 07:49
Was digging into the carbs a bit the other day and noticed one of the carbs was missing the check valve parts in the bowl (ball, weight, clip, o-ring) are these pieces mandatory or is it a better safe than sorry type of thing
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
Last edit: 25 Jun 2015 07:49 by Lazyman06.
Re: Missing check valve parts in carb bowl
25 Jun 2015 12:01 - 26 Jun 2015 07:08
I think the check valve helps to keep the pump nozzles primed with fuel.
Each carb bowl should have a ball, weight & clip, and each nozzle should have an o-ring at the base.
Also, the check valve may keep the accelerator pump circuit from flooding or something like that (see quote):
By WG: The check valve is in each of the four bowls and keeps gas from just filling the accelerator pump circuit without any restraint. There is actually a valve in the bottom of the #2 bowl that you can't get to and often clogs with today's bad gas and then gas is forced into the other pump circuits (the small gas hose hung on the lateral gas barbs on the bowls) through the check valves. The check valves consist of a bb, a small brass "rod" and a wire clip to hold the latter two bits in place. The only way to buy replacements is to buy an accelerator pump kit which includes those items.
Last edit: 26 Jun 2015 07:08 by martin_csr.
25 Jun 2015 13:24 - 25 Jun 2015 13:25
Try jetsRus.
Last edit: 25 Jun 2015 13:25 by SWest.
- jeff80kz1000e2
25 Jun 2015 14:20
I bought mine from redline cycle in Skokie IL
- floivanus
25 Jun 2015 20:09
I deleted the pumps off a set I have, could throw the clip spring etc in an envelope and mail it out; you pay for the stamps
28 pumpers right?
28 pumpers right?
Past; 78 kz1000, 83 kz550
Andrew
Andrew
The following user(s) said Thank You: Lazyman06
- Lazyman06
Re: Re:Missing check valve parts in carb bowl
26 Jun 2015 06:13Sounds great!! As far as I know but I think most of them are the same. Just let me know how much and we'll go from therefloivanus wrote: I deleted the pumps off a set I have, could throw the clip spring etc in an envelope and mail it out; you pay for the stamps
28 pumpers right?
- floivanus
26 Jun 2015 08:14
I can pop the parts out you need, clip spring ball etc, just need one carb's worth?
Send me a PM, we can hash it out
Andrew
Andrew
- Lazyman06
Re: Re:Re:Missing check valve parts in carb bowl
26 Jun 2015 18:57Actually I think I might need 2 sets. Is there supposed to be one on the accel pump bowlfloivanus wrote: I can pop the parts out you need, clip spring ball etc, just need one carb's worth?
