Homemade Carbtune vs store bought?
  • TheForumTroll
  • TheForumTroll's Avatar Topic Author
19 Jun 2015 08:32
#677263
Anyone here seen a comparison / test of a homemade versus a bought one? Someone here doesn't believe that they are accurate and I'd like to show that they are.
-[ KZ700-A1 '84 ]-
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Homemade Carbtune vs store bought?
19 Jun 2015 08:54
#677264
So then do it. B)
  • TheForumTroll
19 Jun 2015 11:33
#677282
Quite hard unless you come by with something to test it against.
-[ KZ700-A1 '84 ]-
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Jun 2015 14:06
#677301
Take a vid of yours and I'll take a vid of mine.
  • TheForumTroll
19 Jun 2015 14:16
#677308
But... you have to test them on the same bike to see the difference.
-[ KZ700-A1 '84 ]-
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Jun 2015 14:23
#677309
I'm going to do a sync on mine soon, I'll take a video.
The following user(s) said Thank You: TheForumTroll
  • TheForumTroll
23 Jun 2015 14:30
#677956
Do you have both a home made and a Carbtune?
-[ KZ700-A1 '84 ]-
  • Tyler
  • Tyler's Avatar
23 Jun 2015 15:21
#677958
So you want to know if a monometer would compare to 4 independent vacuum gauges (like a Morgan carbtune)?
They should do exactly the same thing. one is a relative measurement, the other absolute.
"74 Yamaha DT 400 Enduro
  • TheForumTroll
23 Jun 2015 15:36
#677960
Close, I want to show it to someone who doubts it works like that.
-[ KZ700-A1 '84 ]-
  • TexasKZ
  • TexasKZ's Avatar
23 Jun 2015 15:53
#677966
There are a bunch of YouTube videos of guys using home made rigs. They seem to fall into two basic designs. Some are made with vacuum guages , though those can be bought commercially. The others tend to be made of jars, a bunch of vacuum hose and some oil. Two-stroke and ATF are popular as they are cheap and easy to see. I heard about one made with plastic tubing and ball bearings, much like the factory issued ones from Suzuki back in the day. I have been told by folks who know much more than I that the exact measurement is largely irrelevant as long as they are all the same.
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 Jun 2015 15:58
#677967
I agree. A ball valve can be set differently than the others thus give a false reading. A metering jet/s or check valve/s would help in this case.
  • TheForumTroll
23 Jun 2015 16:11
#677973
I'm using this one:
Attachment tmp_10062-IMG_20150609_235125-1014404329.jpg not found
-[ KZ700-A1 '84 ]-
