Kz750h ltd keihin carb float bowl
- AndrewBat
12 Jun 2015 07:28
So i have explored every other option and determined that my float bowl needs to be replaced. I have replaced the needle, and made sure the floats dont fill up. I leveled all 4 floats and no other bowl leaks. The pin moves just as it should. I replaced the drain screw. Still leaky.
I noticed a tiny hairline crack in the brass straw attached to the bottom of the float bowl and i suspect fuel is leaking out when the fuel level is set correctly due to this crack.
2 questions:
Does anybody have a left side float bowl that will fit a keihin carb for a 1980 kz750h, or know where i can get one? Ebay doesnt have any up.
Also will a right side bowl fit the left side? I dont care if the drain screw is on the wrong side as long as it doesnt leak.
2 questions:
Re: Kz750h ltd keihin carb float bowl
12 Jun 2015 07:38
Sand where the crack is and solder it.
- JR
12 Jun 2015 07:47
The crack can be repaired. I had the same problem. I brought the bowl to a hobby shop and found brass tubing which would just fit over the existing overflow tube. Cut it to length and carefully soldered the bottom. That was 10 years ago. JB Weld will also work if you leave it 24 hours to properly cure.
don't know where you would find a bowl. Left side will fit right side and vice versa. I have mixed them up in the past and as you say the drain screw ends up on the wrong side
- AndrewBat
12 Jun 2015 08:22
Awesome. I think ill just use the right bowl i see on ebay. I tried to solder it today and it didnt come out very well. I sanded, used flux and heated carefully but most of the crack wouldnt take solder. Hard to clean the inside of the crack. And im not bad at soldering either.
Jb weld sounds sketchy. I have my doubts about jb weld in the fuel system. Im sure it would work ok but I prefer not to "fudge" any fixes.
12 Jun 2015 08:27
A layer of solder should do it but if you can buy one, that's best. I'll bet he wants your first born for it. :lol:
- undiablo
12 Jun 2015 08:43
Later Keihin CV34 bowls did not have the brass over flow tube. You can cut it off and block it with some JB weld.
Do not get worry about fuel coming into the cylinder....it will find its way to the airbox. It happened to me a pair of weeks ago.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
