kz1000st air box
- gtrain
kz1000st air box
02 Jun 2015 03:00
Hi there, I just brought a Z 1000st witch is missing a lot of parts like the air box,
will a air box from a kz 1000 mark 2 fit or what other models would fit?
Also what is the idea with the front axle mounted on the front of the fork
legs and a smaller offset on the triple tree, where the mark 2 has the axle on the bottom
of the leg and a larger of set on the tree what different dose is make to handling?
What would be the largest rear tire I can use without hitting the drive tube?
- Nebr_Rex
Re: kz1000st air box
02 Jun 2015 04:14
The ST air box has 3 sections and is not interchangeable.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
The following user(s) said Thank You: gtrain
02 Jun 2015 06:04 - 04 Jun 2015 06:15
If you can't locate a complete airbox anywhere, finding the missing parts is probably going to be a chore. The air filter itself might be hard to find --- Z1Enterprises.com lists a K&N filter, but it's temporarily out of stock w/ no firm delivery date.
You might be able to round up the parts to build an airbox piecemeal on eebbaayy, getting the stuff as it happens to be listed, but that could take a while & get expensive. If something is listed, ask the seller if he has any of the other stuff. I did not check for every part, but right now there are a couple of KZ1000E airbox bodies & a nice silencer & some pricy nos carb duct holder plates. I did not see a cap or the connector duct for the silencer.
Search terms: KZ1000 KZ1000E KZ1000ST E ST 1000E 1000ST
Partzilla --- KZ1000-E2 Shaft (ST)
Last edit: 04 Jun 2015 06:15 by martin_csr.
- roy-b-boy-b
02 Jun 2015 06:53
List this in the parts wanted section and maybe Brian will help you. He found me a complete air box for my ST as well as a lot of other parts for the bike.
- gtrain
Last edit: 03 Jun 2015 02:12 by gtrain.
- kzspartan
03 Jun 2015 19:18
I have an airbox and connecting VS and filter. I will have to get them out of storage if your interested? Not sure of the price.
- gtrain
12 Jun 2015 12:07
Hi there, yes I'am interested in the condition and price of that air box,
Would you send too Australia? (postage is a killer),
also I'am chasing a good complete KZ 1000 instrument cluster to convert
on to my ST? thanks.
12 Jun 2015 14:58 - 12 Jun 2015 15:00
I used a KZ 900 air box on my Z1 because the Z1 box wouldn't fit my 33's. I had to open the holes for larger boots I made up. You might look into maybe a KZP or KZ 1000 air box locally for fitment. The axle placement is for longer travel forks. That's a good thing.
Last edit: 12 Jun 2015 15:00 by SWest.
