New Crankcase Ventilation System for POD Filters
- TheForumTroll
Re: New Crankcase Ventilation System for POD Filters
03 Jun 2015 08:46Xl ED wrote: I know that it is standard from the factory but it is emissions related. Given the choice why would you put dirty air and oil (unfiltered) back into your engine?
Guess it comes down to if you see pollution of the air your engine breathe or the air everything breathes as the most important. I would buy a system like this if it came ready to bolt on -maybe even including the pods- if I were to run pods on my bike (which I'm not though). Great idea!
-[ KZ700-A1 '84 ]-
- floivanus
03 Jun 2015 15:01
All modern vehicles run a sealed crankcase system (typically one hose to the air box inlet, one to a metered valve going to a vacuum source) it isn't just an emissions thing but also for power and efficiency too. The rings are supposed to get a better seal when the engine crankcase is at zero pressure or negative. Yes, you aren't getting full benefit from just having a hose coming off the breather but, you may not get full benefit from the kz setup.
I put a cammed out, high compression motor in my camaro five or six years ago, with them neat breather covers on it, idled for crap, fouled plugs, got crap mileage and would build up enough pressure to spit oil out at times. Put the stock style PCV system back on and all those issues went away.
YMMV
YMMV
Past; 78 kz1000, 83 kz550
Andrew
Andrew
- Nebr_Rex
03 Jun 2015 19:57
Yep, pcv has been common since the 1970s.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
03 Jun 2015 21:50
PCV introduced in 66.
