New Crankcase Ventilation System for POD Filters
Re: New Crankcase Ventilation System for POD Filters
25 May 2015 19:40
The only effect I could see on jetting is the heated air. Might make it run rich.
- VTEC
25 May 2015 19:55swest wrote: The only effect I could see on jetting is the heated air. Might make it run rich.
Again, these are the same blow-by gasses entering the engine that were there when your bike came out of the box.
KZ1000-K2
ZRX1100
XR400R
ZRX1100
XR400R
25 May 2015 20:03
Yes, and they're jetted to the locations at which they are sold.
- loudhvx
25 May 2015 23:38 - 26 May 2015 10:22
The crankcase is sealed except for the vent (not like a car PCV system), so any slight vacuum applied won't increase the ventilation. It reduces the pressure inside the crankcase, but the flow is determined by how much blowby you have. The only way to reduce oil contamination would be to allow for an air intake into the crankcase as well as sucking it out through the vent.
If you put some paper into a jug, and connect a vacuum cleaner hose to the jug, the vacuum can't suck the paper out because there is no air flow (as long as everything is sealed). If you cut another hole, so air can get into the jug, then the paper can get sucked out.
I suppose if the crankcase leaked air, you could get some fresh air flow, but without that, all you are getting for flow is blowby... the very thing contaminating the oil.
In my experience, only bikes with some ring issues had any significant smoke coming out of the vent hose. After it's warm, the water vapor/blowby is usually invisible.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 26 May 2015 10:22 by loudhvx.
- Xl ED
26 May 2015 04:44
I know that it is standard from the factory but it is emissions related. Given the choice why would you put dirty air and oil (unfiltered) back into your engine?
I don't live to ride, I ride to live.
- Nebr_Rex
26 May 2015 06:01Xl ED wrote: I know that it is standard from the factory but it is emissions related. Given the choice why would you put dirty air and oil (unfiltered) back into your engine?
Bingo!
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Nebr_Rex
26 May 2015 06:06swest wrote: Yes, and they're jetted to the locations at which they are sold.
Where did you get this information?
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- New 750
26 May 2015 06:53
Hmm I just have a cheap eBay breather on mine, but with his set up wouldn't that help lubricate the slides in the carb? I though I read somewhere some Hondas had a system like that for lubricating the slides? I could be typing complete foolishness here but it seems legit.
1977 kawasaki KZ750
26 May 2015 06:54
Think about it. My bike won't run for SHT in the high elevations. That's not where it was set up.
- Nebr_Rex
26 May 2015 09:26
Have any documentation stating they were jetted differently?
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
26 May 2015 09:47
Nope, do you? I'll ask my neighbor. He was a dealer in the 70's and 80's.
- loudhvx
26 May 2015 10:26
All parts fiche info only showed one single jetting for the entire U.S. If there was any re-jetting done, it was probably by the dealer.
1981 KZ550 D1 gpz.
Other links.
Other links.
