1978 Z1R: Mikuni Experts. What would you do here?
- 300kph
19 May 2015 14:01 - 19 May 2015 14:25
Been several years since my carbs were off my bike and with it running poorly lately I decided it was time to pull them, bathe them and tune them up.
To my horror I found 2 of the choke tubes (not sure what they are actually called) were broken and had been secured with epoxy. Been so long I cannot remember who did it but I have an idea. '
These tubes are no doubt pressed it. Can the be removed? If so how and can replacements be found.
My mechanic says he will come up with a fix if not.
In a perfect world I would have a spare rack of VM28SS kicking around. Sad thing is I did have a spare rack 10 years ago.
What would Jesus do? Or any Mikuni expert for that matter. Suggestions anyone?
Its carbs 2 & 4 in the picture (also carbs 2 and 4 on the bike when flipped over and mounted)... They are missing from the top left area of carbs (you can see the holes where they are meant to be)
Here`s the fiche... what part is this tube?
W
W
1978 KZ1000 D1 (Z1R)
1979 KZ1000 A3 (MKII)
1979 Honda CBX (Candy Glory Red)
1980 Suzuki GS1100E (Silver)
1980 Suzuki GS1100E (Red)
1978 Yamaha XS1100
1982 Suzuki GSX1100S (Katana)
1984 Kawasaki KZ1100R (Silver)
2004 Honda Rune (Bloodstone Red)
1978 Yamaha XS1100
Last edit: 19 May 2015 14:25 by 300kph.
- missionkz
Re: 1978 Z1R: Mikuni Experts. What would you do here?
19 May 2015 15:24 - 19 May 2015 15:25
If I did not have any other choice then to dump a ton of money in a new set of used carbs, I'd just clean the aluminum alloy casting up, scrape the crap out, and after making sure the brass tube is REALLY clear, carefully epoxy the brass tubes back in but with a greasy +.009" dia wire stuck in it to keep the tube and orifice open and use a good epoxy gusset around the brass to aluminum alloy casting.
Then after a few hours, when they epoxy has really set up hard, spin and or run that fine .009" dia wire through the tiny hole in the brass, and then.... I'd just forget about it put them back on and ride the hell out of the bike.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 19 May 2015 15:25 by missionkz.
The following user(s) said Thank You: Randombeat
- etbike3135
19 May 2015 16:08
those come out real easy with some heat. I don't think you have a problem there. A lot of times I take them out when I'm doing a carb cleaning. You just need to find some off a donor set.
1973 Kawasaki Z1
18 years in dragbikes
19 May 2015 19:25
You have the tubes. They have jet holes in the bottom. Id Mic them, buy a drill that size and reset the ones you have. Who cares if they're 1/4 " short. It's the choke.
- weales
20 May 2015 05:27
One of my carbs on my '78 Z1-R has the choke tube broken off at exactly the same point and I've been working on whether to epoxy/JB weld the original bit back on or drill out the remaining bit and fit a new tube (I have the tube stock but will have to drill the cross holes and blank off the end then drill the .009"hole in the bottom) I'll be very interested to see the best solution here! Please share your thoughts and experiences with this repair so we can all learn.
Current Project
1968 Norton P11A Desert Sled
Other bike (and daily ride)
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
20 May 2015 05:42
Maybe try asking the question at WGCarbs.com in the Vintage Forum.
wiredgeorge doesn't visit KZRider much any more & his fix may be a trade secret. :blush:
I looked in the Archive here on KZR but didn't find anything.
- baldy110
20 May 2015 09:31
FYI guys epoxy will not last if bathed in gasoline, it will break down.
20 May 2015 10:07 - 20 May 2015 10:08
I've used it to seal a float. If not totally encapsulated, it will lose it's stick and leak.
Last edit: 20 May 2015 10:08 by SWest.
- missionkz
20 May 2015 11:07 - 20 May 2015 11:17I don't know if that is 100% true but I'm pretty sure marine grade epoxy is fuel proof and there are probably many other epoxies from manufacturers that are fuel proof.baldy110 wrote: FYI guys epoxy will not last if bathed in gasoline, it will break down.
I'd just call a NAPA dealer and ask about the good stuff.
I just looked around and finding a 100% fuel/alcohol proof epoxy is harder then I thought.
This looks promising but still not claiming 100% fuel proof.
Master Bond EP-41S-1 epoxy resin
Bruce
1977 KZ1000A1
1977 KZ1000A1
Last edit: 20 May 2015 11:17 by missionkz.
20 May 2015 11:36
Those emulsion tubes have their own shaft they fit in. If you'll look at the others, you'll see a hole at the top. I don't think you'll have a problem with shorter ones but make sure you have the right size vent hole there. My 33's have a jet at the bottom of the shaft leading into the bowl. I cleared one of them and noticed a difference. Why? I don't know but I will make sure all of are clear next time I have my carbs off. .
- missionkz
20 May 2015 14:47Steve, I think he is only talking about the 1/8" dia, pick up tube for the choke enrichment system, not the emulsion tube on top of the main jet.swest wrote: Those emulsion tubes have their own shaft they fit in. If you'll look at the others, you'll see a hole at the top. I don't think you'll have a problem with shorter ones but make sure you have the right size vent hole there. My 33's have a jet at the bottom of the shaft leading into the bowl. I cleared one of them and noticed a difference. Why? I don't know but I will make sure all of are clear next time I have my carbs off. .
Well, do they call that pickup tube an emulsion tube also??
Bruce
1977 KZ1000A1
1977 KZ1000A1
- DoctoRot
20 May 2015 17:27 - 20 May 2015 17:29
I had to fix the overflow stem on a set of CV34s. pretty similar problem. this might help you out. BTW i used Seal-All on it. Its supposedly wont deteriorate from gas.
kzrider.com/forum/3-carburetor/596928-re...w-stem-in-float-bowl
Last edit: 20 May 2015 17:29 by DoctoRot.
