How long to run the engine before reading plugs?
  • TheForumTroll
  • TheForumTroll's Avatar Topic Author
01 May 2015 09:38
#670282
How long does the engine need to run at specific throttle inputs before you can read the sparkplugs correctly?
Bonus question:
The Mikuni BS34's (KZ700-A1, KZ750-L3, etc.) mixture screws are adjusting fuel, not air right? In is leaner, out richer?
-[ KZ700-A1 '84 ]-
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: How long to run the engine before reading plugs?
01 May 2015 11:11
#670293
After warm up, 1/4, 1/2, 34/ throttle under load. Kill the engine, coast to a stop.
In is lean/out is rich.
  • TheForumTroll
01 May 2015 11:56
#670302
But for how long to get enough colour on the plugs? I've only done it way back when and read that it takes longer with modern petrol?
-[ KZ700-A1 '84 ]-
