140 main jets!?
- stevets
The tank was clean so I pulled the plugs and loaded all cylinders with wd40 a couple times over several weeks, and found good spark +compression. With a squirt of starting fluid and some battery, she barked to life immediately.
Since then I've replaced the oil, gave the carbs a modest clean up,and new plugs. The original aftermarket air cleaner had disintegrated and I could not find a replacement element so I went with pods. Before the pods I could get the bike to run. Now...no luck. I assumed I needed to jet up and so took off the carbs and found mains marked 140 with 17.5 pilot jets on what I think are 2nd generation 128mm carbs. The bike has a Racer One 4 into one pipe.
Thats the bad news. The good is I think this is actually a Z1 based on the frame number - Z1F-502288 and manufacture date of 10/75.
Based on all I've read here the 140 mains seem huge! So I have a couple questions:
Should I assume some internal mods to warrant the huge mains?
What is the trick to removing an oilfilter cover thats been untouched for 25 years?
It's a really nice looking bike and I had such a boner for one these when i was a youngster that i can't wait to ride this monster. These have such a distinctive engine note it's a rush just to hear that music again. I'll share some pics when it's closer to being re-assembled.
Thanks for the help you've already provided and I appreciate any comments on this thread
- Thank you received: 2756
Good Job.
- stevets
- stevets
- bountyhunter
- Thank you received: 337
Hope you saved the stock airbox. You can get replacement filter elements by size. You buy the metal frame with the foam cell filter element around it and oil it. I have been running one for 30 years.stevets wrote: Hello All, I found a garage find ( parked since 1988) 1976 kz 900 last fall. The bike was clean and modded with a 4 into one, electronic ignition, a 42 tooth rear sprocket and some nice chrome work. I have no other info on any internal mods.
- stevets
- stevets
- stevets
Now it's "just" a matter of figuring out why she starts bogging at about 5000 revs.
