ZR550 CARBS ON A SPECTRE/GPZ550?
- Fastrax
15 Apr 2015 08:10
Has anyone had any experience putting a set of ZR550 carbs on a 1983/1984 550 Spectre or GPZ? The bike we have in the shop has TK carbs on it & parts are hard to find. Someone suggested putting the ZR550 carbs on it, what is involved in this swap?
Re: ZR550 CARBS ON A SPECTRE/GPZ550?
15 Apr 2015 08:37
Jetting?
- Fastrax
15 Apr 2015 09:17
Will the ZR550 carbs fit the GPZ/Spectre intake manifolds or do I have to replace the manifolds also? the air filter side of the carbs doesn't matter because we are running pod filters.
- loudhvx
15 Apr 2015 16:22
It's been done, but I only know of it being done for racing. Look for posts by Corey Clough, or try the Gpz550 forum. He is the guy to ask about the CV30's on a Kz/Zx motor. Sorry, I can't recall if the stock manifolds will stretch enough for the CV30's.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Tyrell Corp
15 Apr 2015 16:48
ZR550 carb spacing is slightly different, manifold rubbers will probably need changing.
The zr are semi flatslide, so in theory a better design than the older TK CV 's.
