kehin CV 34
  • piecrazy4
  • piecrazy4's Avatar Topic Author
kehin CV 34
20 Mar 2015 16:29
#665065
OK guys I have a problem my bike had a set of really messed up carbs so I bought another set and was cleaning them to put them on all was well till I went to clean the idle passage on the side towards the engine three of the adjustment screws came out OK but someone had them six turns out the fourth one the slot stripped out since I have another set for the screw how good of a chance do I have to drill it out and use a extractor or am I going to be better off switching that body for one of my others thank you any help is appreciated
1984 ZN 700 ltd current project
  • Zephyrrider
  • Zephyrrider's Avatar
Re: kehin CV 34
20 Mar 2015 16:40
#665067
Got a pic of the problem area ?
Mick
1994 ZR750 Zephyr C4.
  • JR
  • JR's Avatar
Re: kehin CV 34
20 Mar 2015 17:47
#665072
It's hard to say without seeing it like Zepherrider says. The screw may be brass and easy to drill into but on the other hand it's pretty small so you would need to be careful. I'm kinda thinking though that you have nothing to lose by trying a drill and extractor. At least if you wreck it you have a backup.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: kehin CV 34
20 Mar 2015 21:02
#665079
Your best bet would be a reverse drill bit.
  • piecrazy4
Re: kehin CV 34
21 Mar 2015 01:27
#665089
Thanks everyone I'm going to try later with a reverse drill bit
  • piecrazy4
Re: kehin CV 34
21 Mar 2015 20:38
#665171
Well the reverse drill didn't work but I used a extractor that works both ways and got it out
  • Zephyrrider
Re: kehin CV 34
21 Mar 2015 23:07
#665179
so were you talking about the air mixture screws ?
Mick
  • piecrazy4
Re: kehin CV 34
22 Mar 2015 08:03
#665207
Yes
