Adjusting the Needle Height
- OutsiderKZ900A4
13 Mar 2015 21:02
Is there a good tutorial out there on adjusting the needles on a 1976 KZ900? I have never had a bike that had the carbs linked together in the manner that these are. It acts like I need to raise them up a notch to richen up the midrange a bit. Any help would be appreciated as the factory shop manual doesn't help much in this aspect.
The bike is 1976 KZ900A4.
Thanks again for any assistance.
- SweetwoodSUP
Re: Adjusting the Needle Height
14 Mar 2015 00:31
Raising the needles a notch will richen the mixture across the entire range. That is not always a good thing. It could cause cold blooded starting and a rough idle. What modifications have been made to this bike? Pods? Exhaust? Which jets?
'79 LTD 1000
'84 Ninja 900 (Sold, What was I thinking!)
'81 CSR 305 (sold)
'69 BMW R75 (Sold)
'81 CSR 305 (sold)
'69 BMW R75 (Sold)
14 Mar 2015 07:41 - 14 Mar 2015 07:44
The jet needles have grooves in which a circllip is placed. The clip can be moved to a different groove to either raise or lower the needles. I'm not familiar with your carbs, but I guess access is by removing the carb tops, then removing the throttle slide assys. Removal of the throttle slide shaft & other stuff may be necessary. not sure.
Some jet needles don't have the grooves. In those cases small washers can be used to raise the needles. I guess for precision tuning, washers could be used on the type w grooves to obtain a needle setting between two grooves.
Groove numbers. There is a table in the 81 650 manual, which shows a Jet Needle number of 5CN15-4. The "4" is the groove number for the stock placement of the clip. The groove numbers are counted from the topmost groove, 5 being the lowest groove.
Last edit: 14 Mar 2015 07:44 by martin_csr.
14 Mar 2015 08:20 - 14 Mar 2015 08:29OutsiderKZ900A4 wrote: Is there a good tutorial out there on adjusting the needles on a 1976 KZ900? I have never had a bike that had the carbs linked together in the manner that these are. It acts like I need to raise them up a notch to richen up the midrange a bit. Any help would be appreciated as the factory shop manual doesn't help much in this aspect.
Before attempting any carb adjustment, and if not already done, would assure that the carbs are as-new clean, especially the pilot circuit.
Perform a proper bench-sync, being sure to allow ability to further drop the throttle slides when performing the later running-sync.
Adjust valves. Install new spark plugs. Assure ignition timing is spot-on.
Install a new aftermarket in-line fuel filter in each fuel line. And don't let any gasoline enter the freshly cleaned carbs without first passing through the in-line filters.
Then, after all the above, perform the running-sync. And set pilot air screws for best idle.
Test ride to decide whether or not any further carb adjustment might be indicated.
Last edit: 14 Mar 2015 08:29 by Patton.
14 Mar 2015 11:57
The needles are set at the factory. The adjustment is for minor changes not to compensate for jetting. The slide cutaway, nossle and needle are a matched set. Minor changes in altitude can be compensated with the needle and air screw. It's best to leave them in the center position if possible.
- gd4now
- Denco where did you go?
14 Mar 2015 13:19
For each change in the needle placement (up or down) there will be a difference in the mixture strength as follows:
At low throttle opening 3 to 6%
At mid throttle opening 5 to 8%
At wide open throttle 1 to 2%
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- OutsiderKZ900A4
Re: Re:Adjusting the Needle Height
14 Mar 2015 14:00
Maybe I should rephrase my question... How does remove the needles/sliders from the carburetors on the KZ when they are linked by a shaft that connects all 4 of them?
14 Mar 2015 14:09
Take the tops off, on yours three screws. Inside you will see the shaft. There is a small bolt holding the arm. Be careful not to shear the bolt loosening or tightening it. There are two screws at the bottom inside if the slides. Take them out. Rotate the arm and linkage up and out of the way. Pull the slide out.
If you had a manual you wouldn't be asking this. I suggest you get one. Sometimes the carbs are switched. It helps to show pics of what you have.
- OutsiderKZ900A4
14 Mar 2015 14:16
I have a factory shop manual but it was not much help in this instance, unless I am not looking in the right spot...
- OutsiderKZ900A4
14 Mar 2015 14:41
And swest, thanks again for your post, it was exactly what I was looking for. I appreciate it.
- missionkz
14 Mar 2015 14:47 - 14 Mar 2015 14:54
I hope I'm not forgetting anything....I've done it many times so take this worth a grain of salt, but I find it much easier to pull carbs off the bike, remove the return spring, take the tops of the carb bodies, remove all four of the lock screw/bolts from each carb slide arm, remove the shaft clamp and and then slide the entire shaft out of the carb holder block.
Then you can just pull the arms with the slide all the way out. Easy to remove the two little screws that hold the arm assembly cap to the slide and pull the needle out.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 14 Mar 2015 14:54 by missionkz.
14 Mar 2015 14:53
I've never done it like that or knew anyone else to do it. What if you want to go the other way?
This way you can do it in the bike. The carbs need to be synced anyway but one at a time isn't as drastic.
